The response to clicks does not work correctly - Printable Version
+--- Thread: The response to clicks does not work correctly (/showthread.php?tid=8069)
The response to clicks does not work correctly - skench - 05-11-2025
Hello, I configured the kincony A8 v1.6 as follows. I have the latest firmware available for this model at the moment v2.2.13.
I am trying to configure the switch so that a single press turns on relay 8, and a long press turns on relays 1 through 4, but I don't like that even if I make a long press, relay 8 turns on, which should only turn on with a short press, and I don't want to constantly turn it off after making unnecessary movements, how can I fix this?
The goal is to turn on relay 8 with a short press, turn on relays 1 through 4 with a long press, and not even turn on relay 8.
A video demonstrating my setup is below.
https://cloud.mail.ru/public/kzD9/foVXqnA1Z
Help me PLZ.
RE: The response to clicks does not work correctly - admin - 05-12-2025
after you config IFTTT. do you have re power on of board? it MUST need reboot.
RE: The response to clicks does not work correctly - skench - 05-12-2025
(05-12-2025, 01:08 AM)admin Wrote: after you config IFTTT. do you have re power on of board? it MUST need reboot.
Yes, I tried rebooting the equipment, but it doesn't help, when holding the key for a long time, relay number 8 still works, I tried working with different IF by enabling the logical AND parameter, but my attempts have been unsuccessful so far.
we will test.
RE: The response to clicks does not work correctly - skench - 05-24-2025
(05-12-2025, 08:40 AM)admin Wrote: we will test.
Good afternoon, please advise the time frame for my question, when will you be able to test it?
RE: The response to clicks does not work correctly - admin - 05-30-2025
we will test after 1 week, because KC868-A8 not in stock now.
RE: The response to clicks does not work correctly - admin - 06-03-2025
if you want use click and hold on at the same time, you should chose "single click" instead of "rising edge". we have tested ,it's ok.
RE: The response to clicks does not work correctly - skench - 06-05-2025
Thanks, I'll really be able to check in 2 weeks.
I have kincony controllers already assembled in the dashboard.
Thank you very much, I love your product.
RE: The response to clicks does not work correctly - admin - 06-05-2025
ok, good.
