i2c lcd_pcf8574 not working - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A2 (https://www.kincony.com/forum/forumdisplay.php?fid=43) +--- Thread: i2c lcd_pcf8574 not working (/showthread.php?tid=8322) |
i2c lcd_pcf8574 not working - simdollaro - 07-17-2025 i got this issue [22:24:38][C][lcd_pcf8574:024]: PCF8574 LCD Display: [22:24:38][C][lcd_pcf8574:024]: Columns: 20, Rows: 4 [22:24:38][C][lcd_pcf8574:028]: Address: 0x27 [22:24:38][C][lcd_pcf8574:029]: Update Interval: 0.5s [22:24:38][E][lcd_pcf8574:031]: Communication failed [22:24:38][E][component:088]: Component display is marked FAILED: this my config esp32: board: esp32dev framework: type: esp-idf ............... i2c: sda: GPIO4 scl: GPIO16 id: i2c0 scan: true #frequency: 100kHz display: - platform: lcd_pcf8574 dimensions: 20x4 i2c_id: i2c0 address: 0x27 update_interval: 500ms lambda: |- it.strftime(0,0, " %d-%m-%Y %H:%M", id(sntp_time).now()); it.printf(0,1, "T Est %.1f-T Int %.1f", id(tt_ext).state, id(tt_int).state); it.printf(0,2, "GIARD %s SCALE %s", id(giardino).state ? "ON" : "OFF" , id(scale).state ? "ON" : "OFF"); it.printf(0,3, "GIARD %.0f SCALE %.0f", id(giardino_work_time).state, id(scale_work_time).state); -------------- what's wrong? I already changed more displays , try invert sda/scl, try 3.3v and 5v also... RE: i2c lcd_pcf8574 not working - simdollaro - 07-18-2025 found firts problem, the right address is 0x3F... the error now is resolved but in the screen don't see any chars... have you tested the same hardware before? regards found firts problem, the right address is 0x3F... the error now is resolved but in the screen don't see any chars... have you tested the same hardware before? have to introduce some resistor in the i2c bus? regards RE: i2c lcd_pcf8574 not working - simdollaro - 07-18-2025 everythinghs ok now.. sorry for this posts... changed contrast trimmer and all is ok. gread KC868-A2 I love you RE: i2c lcd_pcf8574 not working - admin - 07-18-2025 ok, good. |
