KC-868 COLB - I do not see IP adress - Printable Version
+--- Thread: KC-868 COLB - I do not see IP adress (/showthread.php?tid=8590)
Pages: 1 2
KC-868 COLB - I do not see IP adress - Alois Láska - 09-28-2025
Hi,
I have successfully set up the Kyncony KC-868 A4, and using Node-RED with HTTP requests I can now switch the relay. From here, it’s only a matter of programming the desired algorithm.
But since the A4 has a limited number of analog inputs, we also got the KC-868 COLB.
I have successfully upgraded the firmware of the COLB to the latest version using the guides from the forum.
When I use VirCom or IP Scanner software to search for the COLB device in the network, it doesn’t find any COLB. That’s why the SCB software doesn’t work either.
I connected the COLB via Ethernet cable to a switch that assigns IP addresses through DHCP. The laptop I am using is also connected to the same network.
Could you please tell me where I am making a mistake? Do you have a precise guide or step-by-step instructions on how to connect the COLB?
Additional questions:
– Is it possible to connect the COLB via WiFi as well? I am confused by your guides, it’s not clear to me. If yes please send me some guide how.
– How many DS18B20 digital sensors can be connected to a single channel? Only one?
Thank you very much for your assistence,
ALois
RE: KC-868 COLB - I do not see IP adress - admin - 09-28-2025
COLB not use by Vircom software, just use by web browser. you can take a photo of your controller.
COLB also support wifi + ethernet.
DS18B20 only connect with one input ports, so MAX is 5pcs of DS18B20 connect with COLB.
RE: KC-868 COLB - I do not see IP adress - Alois Láska - 09-29-2025
(09-28-2025, 10:48 PM)admin Wrote: COLB not use by Vircom software, just use by web browser. you can take a photo of your controller.
Please send me guide how to use with web browser. Or link to dedicated video.
Photo of my COLB attached
RE: KC-868 COLB - I do not see IP adress - admin - 09-29-2025
here is online guide: https://www.kincony.com/how-to-use-kc868-colb-programmable-logic-controller.html
RE: KC-868 COLB - I do not see IP adress - Alois Láska - 10-02-2025
(09-29-2025, 11:05 AM)admin Wrote: here is online guide: https://www.kincony.com/how-to-use-kc868-colb-programmable-logic-controller.html
Finally I managed to connect to the COLB. Thank you for the link!
It seems that your products are very interesting and useful, but what I am struggling with is the lack of clear and concise manuals for the given device.
But your replies on the forum are quick and accurate, which compensates for it a little.
I have another questions:
- On one picture of the COLB I noticed that the input voltage of the AI inputs is only 0–5 V. Therefore, I need to reduce the 0–10 V signal to half – using a standard resistor divider I assume?
- I have KC-868 A4 and KC-868-COLB in the system and I need to measure more temperature points (app 20). Please give me some recomendation from your products how to do it. I thought that it was possible to connect multiple DS18B20 sensors to a single channel, since it is an addressable sensor, but according to your reply this is not possible…
I apologize for the silly questions, but I am trying to get a deeper understanding of your product portfolio and design philosophy. Normally, we either use pre-configured controllers, and for more complex systems we rely on standard PLCs.
thank you
RE: KC-868 COLB - I do not see IP adress - admin - 10-02-2025
1: yes, COLB analog input use by 0-5v, if you want to use 0-10v, need convert.
2: suggest you chose kincony esp32s3 board, because of we will release new KCS v3 firmware, will support one GPIO with multi DS18B20 sensors.
(10-02-2025, 02:37 PM)admin Wrote: 1: yes, COLB analog input use by 0-5v, if you want to use 0-10v, need convert.
Please
- send me a link to the mentioned product  (you have too many products, that still I am lost in all that verison and variants)
- How many sensors you can have in GPIO  in firmware v3? When the fw will be released?
1: you can select product by this link: https://mq.kincony.com/qq/product/product-selector
2: maybe after 2-3 weeks will release. max support 30pcs sensors by one gpio.
RE: KC-868 COLB - I do not see IP adress - Alois Láska - 11-03-2025
(10-02-2025, 10:42 PM)admin Wrote: 1: you can select product by this link: https://mq.kincony.com/qq/product/product-selector
Hi,
COLB and A4 works very well!!
Any news about the new fw supports 30pcs temperature sensor on one gpio?
Thanks
RE: KC-868 COLB - I do not see IP adress - admin - 11-03-2025
KinCony ESP32S3 board use by KCS v3 firmware, now support multi DS18B20 sensors by one GPIO, max 32pcs sensors.
