KC868-A8 Relay Delay - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: KC868-A8 Relay Delay (/showthread.php?tid=8890) |
KC868-A8 Relay Delay - sson6203 - 01-08-2026 I am using a KC868-A8 board. I am using it in a setup where a standard wall light switch provides a contact signal to KC868-A8 Input-1, and this triggers Relay 1 to operate. Sometimes the relay turns off late, or the light does not turn on when I switch the wall switch ON, or it turns on late. I suspect this might be due to contact bounce (chattering). Is there any solution for this? Can this be resolved within the KC868 UI through a firmware update? Using ESPHome to add an input delay feels burdensome for me. I am not good at coding. Controlling it through the UI is more convenient and preferable for me. RE: KC868-A8 Relay Delay - admin - 01-09-2026 IF DI chose "Raise edge" , not chose "True". |
