E16V3 - Noise reduction - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Suggestions and feedback on KinCony's products (https://www.kincony.com/forum/forumdisplay.php?fid=39) +--- Thread: E16V3 - Noise reduction (/showthread.php?tid=9030) |
E16V3 - Noise reduction - ldebacker - 02-08-2026 Hi, The E16V3 works great so far. I would just like to suggest an enhancement for future versions... The relays, when changing state, generate some noise, which is normal. However, the added cover is metallic, and it resonates quite a lot when the relays are changing state. May be some internal isolation could be added to reduce the noise levels ? Thanks in advance for considering the suggestion. Best regards, Laurent RE: E16V3 - Noise reduction - admin - 02-08-2026 thanks for your suggestion. |
