2 channel network relay controller
Products Parameter: Dimension:      73x117x40mm Working Voltage: DC 12V Material:Fire resistance ABS、metal shell Working Temp: -20℃~70℃ Working Humidity: 20%RH ~ 80%RH Output Load:each 250V/10A Communication mode:Ethernet/RS232 Output port qty:2 ports   The following information introduces KC868-H8 controller. KC868-H4, KC868-H2, KC868-H8, KC868-H32 controller are KC868 series of KinCony's products, so phone APP and PC software […]
Contact Us
Products Parameter:
The following information introduces KC868-H8 controller. KC868-H4, KC868-H2, KC868-H8, KC868-H32 controller are KC868 series of KinCony's products, so phone APP and PC software are compatible. There are only different input and output channel.
network relay
Brand New Packaging:network relay
network relay
Products Function:
2. Remote controlling the opening/closing of 2 routes or 2 groups’ circuits.
3. Supporting secondary development
4. Supporting APP remote controlling
5. Widely used for lights controlling of kinds of occasion (like Indoor, theater or Amusement Park etc) and switching of mechanical equipments, and management of the computers in the cyber bar and so on.
Products Features:
2. each route is equal an independent switch.
Products Usage Instructions
Wiring and Installation
2. Connecting the lamp and power with relays output COM and NO port.
3. When need to control one group or groups lights, connecting the line into the corresponding output poles.
4. Connecting the 12V power adapter to charge.
kc868-h2-diagramnetwork relay
The newest Andorid Software , Download form our webpage(not in Google Play): https://www.kincony.com/download/Smart-Home_Eng.apk
This is PC software for KC868-H8, It can control by LAN (local control) or WAN (remote control)
network relay
new software support CCTV (only use for KinCony's ipcamera product). When you see the video control the relay switch.network relay
This is config manu, The title and copyright and all relays' name can be changed by yourself.
If you connect with "KC868 Voice Assistant" module, controller can control voice control by Amazon Alexa or Google Home Speaker or Amazon Alexa or Google Home phone APP.
network relay
