Home automation training courses
Threads
- Lesson4 - Install Home Assistant Operating System (21 Replies)
- Lesson14 - integrate DS18B20 temperature sensor to home assistant (10 Replies)
- Lesson9 - integrate KC868-Server to home assistant by MQTT (51 Replies)
- Adding wifi setup button with Homespan (3 Replies)
- Lesson16 - integrate ZigBee device to home assistant by Zigbee2MQTT (5 Replies)
- Lesson1 - Course introduction (4 Replies)
- Lesson19 - add water level sensor for automation in home assistant (18 Replies)
- Lesson10 - install wall switch panel (2 Replies)
- How can the configuration files be separated in the configuration.yaml file? (1 Reply)
- Lesson22 - add RGBW LED strip to home assistant by ESPHome (16 Replies)
- lesson32 - set button work for latch,inching,momentary, Interlocking work mode by ESP (2 Replies)
- Lesson11 - how to use by own 433MHz RF / infrared remoter (18 Replies)
- Lesson24 - home assistant remote access by FREE DuckDNS (5 Replies)
- Lesson3 - Make a smart power distribution box (3 Replies)
- Home Automation Power distribution Box - Lesson 3 (15 Replies)
- Lesson13 - integrate KC868-AG to home assistant control air conditioner by IR (23 Replies)
- lesson34 - how to install Zigbee 3.0 gateway to home assistant (5 Replies)
- how to install docker on KC868-Server CM4 by raspberry pi OS (0 Replies)
- USE PCF8574 FOR ESP32 INPUT PORTS (10 Replies)
- How can I add ZigBee gateway to the homeassant ? (3 Replies)
- Lesson31 - control modbus relay by Node-Red (2 Replies)
- How can the dashboard be customized for each user? (1 Reply)
- lesson33 - make a 3D dashboard for home assistant (4 Replies)
- Lesson30 - how to install Node-Red on home assistant (0 Replies)
- Lesson29 - how to config manual push button for switches and LED strip (0 Replies)
- Lesson28 - How to send command control RS485 curtain motor (0 Replies)
- Lesson27 - Notifications for Android TV in home assistant (0 Replies)
- Lesson26 - send email notifications by sensor in home assistant (0 Replies)
- Lesson25 - how to use Apple HomeKit by home assistant (0 Replies)
- Lesson23 - any controller input trigger any controller output (0 Replies)
- Lesson21 - Install Raspberry Pi OS on KC868-Server (0 Replies)
- Lesson20 - extend hardware digital output and input channels in home assistant (0 Replies)
- Lesson18 - add ZigBee PIR motion sensor to auto control light in home assistant (0 Replies)
- Lesson2 - Preparations before building a smart home (5 Replies)
- Lesson17 - integrate USB local camera to home assistant (0 Replies)
- Lesson15 - control IR device by Infrared extender cable (0 Replies)
- Lesson12 - integrate KC868-Uair to home assistant to monitor temperature & humidity (0 Replies)
- Lesson8 - install Mosquitto broker on home assistant (0 Replies)
- Lesson7 - install home assistant mobile phone application (0 Replies)
- Lesson6 - configure integration of home assistant (0 Replies)
- Lesson5 - Add-on Samba and file structure of home assistant (0 Replies)
