KC868-HxB series Smart Controller
Threads
- Request for firmware H32 (1 Reply)
- KC868-A8 on Heat Pump for SG-Ready (1 Reply)
- KC868-COLB - How to Connect by Ethernet and DHCP (6 Replies)
- replace resistance for COLB switch analog input from 0-5v signal to 4-20mA (0 Replies)
- KC868-D16 dimmer controller MQTT configuration for home assistant fixed linear issue (13 Replies)
- KC868-H16B Mqtt stops working intermittently (1 Reply)
- Where to get schematics of all KC868-A8 and A16 versions with relays ?? (1 Reply)
- KC-868 COLB - I do not see IP adress (18 Replies)
- KC868-H32B Pro (3 Replies)
- KC868-A8V3 and ESPHome firmware (7 Replies)
- Input and output on same pin (5 Replies)
- Using 24VAC with KC868-A16 Board Outputs (3 Replies)
- D16 Dimmer - Set memory value without turning on via MQTT? (6 Replies)
- UE CE certification (3 Replies)
- KC868-H32B Pro wrong firmware update (1 Reply)
- H32BS - MQTT Topic to get states of switches (2 Replies)
- KC868-D16 Home Assistant (2 Replies)
- Unable to connect with firmware tool (1 Reply)
- H32BS & Serial Switch Terminal board (1 Reply)
- Help Needed: KC868-A4 Relay Module Integration with Home Assistant (3 Replies)
- How to Integrate KC868 Smart Controller with Home Automation System ?? (2 Replies)
- H32B smar home app connection (7 Replies)
- revive old broken H32B (7 Replies)
- What's H32B firmware how to download (3 Replies)
- Knox (12 Replies)
- can not login to ifttt (1 Reply)
- Specifications lack of information for KC868-HxB (3 Replies)
- KC868-D16 firmware update (1 Reply)
- KC868-A16 - Custom Form Wifimanager Root content (1 Reply)
- 2wire 4-20ma water sensor (8 Replies)
- kincony relay 4ch (1 Reply)
- Trigger Outputs (5 Replies)
- Can't Connect Over LAN (34 Replies)
- KC868-HA ESP32 arduino demo code work with KC868-A8S (4 Replies)
- hello, i have a question about the relay board (14 Replies)
- KC868-H32BS connecting with external relays / switches (5 Replies)
- KC868-A16 output power (1 Reply)
- KC868-H32 Relay Controller REV:2.4 Problem after firmware update (5 Replies)
- MQTT over wifi not work (9 Replies)
- H32L - home assistant (20 Replies)
- KC868-H32B momentary switch self reset (3 Replies)
- Need help with configuration of multiple controllers in the same house (32 Replies)
- home assistant RC 2022.6 mqtt config update for configuration.yaml (53 Replies)
- Door Access Control System (3 Replies)
- H32BS questions (1 Reply)
- HC868-AK firmware update (6 Replies)
- USB-C Connectivity and COM Port Issue with KC868-A4S Relay Controller (4 Replies)
- Help whit update Cold CPU BOOTLOADER by Jlink tool. (3 Replies)
- H32W Firmware (5 Replies)
- H32B Pro No integration possible in Home assistant (5 Replies)
