KC868-A8
Important Threads
- KC868-A8 ethernet work with home assistant by ESPHome configure (9 Replies)
- how to integrate KC868-A8 to home assistant by MQTT (46 Replies)
- Lesson25- how to send alert message to Whatsapp by KC868-A4 A8 (ESP32) (21 Replies)
- [Arduino IDE demo source code for KC868-A8]--#11-Ethernet_Web server_code (6 Replies)
- Lesson29- How to use tasmota for KC868-A8 via PCF8574 IIC extend GPIO (54 Replies)
- [Arduino IDE demo source code for KC868-A8]--#10-Web server_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#09-RF SEND (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#08-Serial control relays (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#07-PCF8574-DO (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#06-PCF8574-DI (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#05-LAN8720-UDP (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#04-DS18B20 (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#03-ADC INPUT (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#02-RF_receive (0 Replies)
- [Arduino IDE demo source code for KC868-A8]--#01-config Arduino IDE for ESP32 module (0 Replies)
Threads
- INCREMENTAL ENCODER (3 Replies)
- KC868-A8 OpenPLC Function Blocks for Digital input (0 Replies)
- KC868-A8 OpenPLC Function Blocks for RELAY (0 Replies)
- how to use KC868-A8 with PLC ladder diagram using OpenPLC video tour (0 Replies)
- A8 lost network connection via LAN (20 Replies)
- connecting sensors (5 Replies)
- flasg esp unexpected error (15 Replies)
- ESPHome Compile warning message (1 Reply)
- KC868-A8 Relay Delay (1 Reply)
- KC868-A8 ESP32 I/O pin define in Arduino IDE (1 Reply)
- KC868-A8 simple switch (3 Replies)
- Operation (3 Replies)
- Using KC868_A8 as switch (3 Replies)
- Request for Technical Support – Controlling KC868-A8 Relays via Physical Buttons (1 Reply)
- How to connect photo rezistor (LDR) (1 Reply)
- I2C Communication Failure between Kincony KC868-A8 and ESP32C3 (1 Reply)
- Polarity Powering KC868-A8 (3 Replies)
- KC868 KCSv2.2.13 MQTT Update Issue (9 Replies)
- KC868-A4 and A8 plastic enclosure 3D printer stl file (7 Replies)
- Home Assistant mqtt don't works - inputs/outputs unavailable (3 Replies)
- The response to clicks does not work correctly (8 Replies)
- connect Unifi-DoorHub "chime output" (0->12V shift) to Kincony digital input (1 Reply)
- [Bug] Network (5 Replies)
- RFID reader (8 Replies)
- Analog Input voltage incorrect (1 Reply)
- More than 1 1wire sensor ? (1 Reply)
- Connect LD2420 Presence detection sensor to A8 controller. (5 Replies)
- A8 Ethernet strange malfunction (1 Reply)
- How to measure a gas meter with a reed sensor and a KC868-A8 board (1 Reply)
- Issue with http request - Says http not open (12 Replies)
- Kc868 a8 in workshop (12 Replies)
- Connecting Photoelectric (laser) meter (3 Replies)
- KC868-A8 Schematic (7 Replies)
- no access to kcs (5 Replies)
- KC868-A8 board esphome + Tuya + Mqtt (1 Reply)
- KC868-A8 ETHERNET WEB SERVER PLATFORMIO IDE (1 Reply)
- Hardware issues (1 Reply)
- KC868-A8 board esphome + Tuya (12 Replies)
- KC868-A8 and PCF8574 Interrupt pin (14 Replies)
- KC868-A8 Web interface issue (1 Reply)
- Digital input 11.2v (1 Reply)
- KC868-A8 Ethernet Problem (0 Replies)
- KC868-A8 Ethernet Problem (15 Replies)
- Cannot flash firmware, A8 not showing as connected serial device (1 Reply)
- KC868-A8 using RF 433mhz with ESPhome (7 Replies)
- KC868-A8 V1.5 PCF8574 (0 Replies)
- PWM Output on KC868-A8 (8 Replies)
- Ethernet and requests (4 Replies)
- Time display issue in the KC868-A index page (3 Replies)
- SmartHome app compatibility (1 Reply)
