KC868-A8S
Important Threads
- [Arduino IDE demo source code for KC868-A8S]--#18-Read Modbus sensor by RS485 (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#07-KC868-A8S_PCF8574-Digital output_co (2 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#17-A8S_Digital input_Ethernet_Web_serv (7 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#12-Send SMS to many phone numbers (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#11-KC868-A8S_AT-debug_code (1 Reply)
- [Arduino IDE demo source code for KC868-A8S]--#16-KC868-A8S_Ethernet_Web_server_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#15-KC868-A8S_Web_server_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#06-KC868-A8S_PCF8574-Digital input_cod (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#05-KC868-A8S_LAN8720_UDP_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#04-KC868-A8S_DS18B20_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#03-KC868-A8S_BEEP_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#02-KC868-A8S_ADC_INOUT_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#01-KC868-A8S_433_receive_code (0 Replies)
Threads
- DTSU 666 energy meter - any code? (1 Reply)
- A8S and Modbus sensor (16 Replies)
- A8S/A8Sv2 home assistant yaml for KCS mqtt digital input and output (0 Replies)
- A8s v2 inputs not working when using PoE (5 Replies)
- Authentication failure (6 Replies)
- Home Assistant authentication for kincony boards (2 Replies)
- A8s v2 inputs (11 Replies)
- kc868-A8S v2 not working with SIM7600E (9 Replies)
- A8S v2. Incorrect wiring of toggle switches module (1 Reply)
- Sms relays control (6 Replies)
- RS485 modbus energy meter integrate to ESPHome yaml file for home assistant (18 Replies)
- 433MHz remote_receiver (3 Replies)
- AM2301 (8 Replies)
- Ajuda (2 Replies)
- A8S V2 circuit diagram (0 Replies)
- Scan Device List Not Working (3 Replies)
- modbus on KC868-A8S (1 Reply)
- Kc868-A8S_sms-control (3 Replies)
- KCS + modbus + HA (4 Replies)
- input sensors (4 Replies)
- esphome yaml file with ADC analog input 0-5v and 4-20mA for KC868-A8S/A8Sv2 (0 Replies)
- display oled ssd 1306 (3 Replies)
- KC868-A8S ESP32 I/O pin define (5 Replies)
- water level sensor 4-20ma, 0-100cm, 12v ? (3 Replies)
- serial port issue (3 Replies)
- A8S config yaml for home assistant integration by KCS mqtt (0 Replies)
- KC868-A8S circuit diagram (0 Replies)
- Homespan Example (6 Replies)
- ESPhome - connect pressure transducer? (3 Replies)
- How to wire up float switch and use in ESPHome? (3 Replies)
- 12v irrigation solenoid getting really hot! (5 Replies)
- Tasmota Configuration file or Precompiled firmware for KC868-A8S (11 Replies)
- Dali-2 (1 Reply)
- NTC 10k (5 Replies)
- Do I have a faulty LAN chip? (5 Replies)
- KC868-A8S hotel room demo configure for ESPhome (16 Replies)
- Automatically turns off when becoming offline in Home Assistant (1 Reply)
- how to use Mqtt,tcp modbus using ethernet port? (5 Replies)
- wifi port as AP in home Assistant (1 Reply)
- kc868-A8s (12 Replies)
- Problem using KC868-A8S (7 Replies)
- 24vdc power supply (1 Reply)
- SIM7100_SIM7500_SIM7600 Series Windows USB driver (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#14-KC868-A8S_mqtt-relay_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#13-KC868-A8S_sms-relay_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#12-KC868-A8S_sms_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#10-KC868-A8S_GSM_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#09-KC868-A8S_RS485_code (0 Replies)
- [Arduino IDE demo source code for KC868-A8S]--#08-KC868-A8S_WS2812-RGB_LED_code (0 Replies)
