KC868-E16S/E16P
Threads
- KC868-E16S/E16P demo configure for ESPhome (16 Replies)
- E16P Case / Cover (1 Reply)
- Not able to connect (1 Reply)
- Goes Offline (5 Replies)
- Update ESPHome-Firmware 2023.12.9 -> 2025.10.1 (1 Reply)
- LAN8720 (11 Replies)
- [Arduino IDE demo source code for KC868-E16S]--#08-E16S-Ethernet_Web_server_code (10 Replies)
- How to Use Single Click, Double Click, and Hold Click with KCS868-E16S in Home Assist (1 Reply)
- Manual Control Switches Not working (3 Replies)
- E16S home assistant (5 Replies)
- TUYA LICENSE (1 Reply)
- Power supply (1 Reply)
- E16P POE Support (5 Replies)
- KC868-E16S - Multiple (7 Replies)
- EZO sensor not working (14 Replies)
- K868-E16S use digital input and I2C in the same time (8 Replies)
- KC868-E16S ESP32 I/O pin define (4 Replies)
- question (1 Reply)
- ProblemKC868 (1 Reply)
- KNX/RS485 (1 Reply)
- Roller shutter in Home Assistant (1 Reply)
- Cant make E16P work with apple homekit (1 Reply)
- Struggling to get a KC868-E16S working with ESPHome/Home Assistant (1 Reply)
- E16p Analog Inputs (3 Replies)
- KC868-E16S ESP Home configuration with Home Assistant (8 Replies)
- KC868-E16S wiring diagram (0 Replies)
- Difference between E16v2 & E16s (1 Reply)
- KinCony E16P ESP32 I/O pin define (0 Replies)
- Free gpio in KC868-E16S (3 Replies)
- convertir los 4 pines analogicos de 0-5v (1 Reply)
- Are output relay of kc868-E16S dry contact use for 12V DC or 220 volt AC? (3 Replies)
- KC868-E16S board/schematic errors (7 Replies)
- ESPHOME KC868-E16S (11 Replies)
- [Arduino IDE of KC868-E16S]--#00-KC868-E16S-configure for ESPhome (13 Replies)
- Can A1 to A4 used as buttons too? (7 Replies)
- Size of the case (5 Replies)
- RS485 Esphome (1 Reply)
- [Arduino IDE demo source code for KC868-E16S]-09 Work with Apple Homekit (0 Replies)
- [Arduino IDE demo source code for KC868-E16S]--#07-KC868-E16S-Web_server_code (0 Replies)
- [Arduino IDE demo source code for KC868-E16S]--#06-KC868-E16S-RS485 (0 Replies)
- [Arduino IDE demo source code for KC868-E16S]--#05-KC868-E16S-LAN8720_UDP (0 Replies)
- [Arduino IDE demo source code for KC868-E16S]--#04-KC868-E16S-ADC_IN (0 Replies)
- [Arduino IDE demo source code for KC868-E16S]--#03-KC868-E16S-8574-DO (0 Replies)
- [Arduino IDE demo source code for KC868-E16S]--#02-KC868-E16S-8574-DI (0 Replies)
- [Arduino IDE demo source code for KC868-E16S]--#01-KC868-E16S-433-decode (0 Replies)
