KC868-A32/A32 Pro
Important Threads
- [arduino code examples for A32 Pro]-10 How to test AT command with SIM7600 4G modulde (1 Reply)
- KC868-A32 configure for ESPhome (29 Replies)
- A32 Pro ESPHome yaml for home assistant (1 Reply)
- [arduino code examples for A32 Pro]-01 Turn ON/OFF relay (5 Replies)
- [arduino code examples for A32 Pro]-11 How to use digital input port trigger relay (2 Replies)
- [arduino code examples for A32 Pro]-12 How to use DHT11 temperature humidity sensor (0 Replies)
- [ESP-IDF code examples for A32 Pro]-02 Read digital input ports state (0 Replies)
- [ESP-IDF code examples for A32 Pro]-01 Turn ON/OFF relay (0 Replies)
- [arduino code examples for A32 Pro]-09 How to output DC0-10v from GP8403 DAC port (0 Replies)
- [arduino code examples for A32 Pro]-08 Print TEXT on SSD1306 OLED displayer (0 Replies)
- [arduino code examples for A32 Pro]-07 Communication between ESP32-S3 and Tuya module (0 Replies)
- [arduino code examples for A32 Pro]-06 Ethernet W5500 chip work with TCP Server mode (0 Replies)
- [arduino code examples for A32 Pro]-05 Read free GPIO state (0 Replies)
- [arduino code examples for A32 Pro]-04 RS485 communication test (0 Replies)
- [arduino code examples for A32 Pro]-03 Read analog input ports value (0 Replies)
- [arduino code examples for A32 Pro]-02 Read digital input ports state (0 Replies)
- A32 Pro ESPHome yaml for home assistant and Tuya app work simultaneously without MQTT (0 Replies)
- A32 Pro ESP32 io pins define (0 Replies)
Threads
- KC868-A32 : PSU 24VDC (3 Replies)
- A32 Pro (12 Replies)
- KC868-32 arduino ide (8 Replies)
- [Arduino IDE demo source code for KC868-A32]--#05-PCF8574-DO (2 Replies)
- A32 pro and IFTTT (8 Replies)
- Wired ZigBee 3.0 integration with HA (1 Reply)
- access control panel by wiegand protocol configure yaml for ESPhome (13 Replies)
- KC 868 A32 (4 Replies)
- create cover buttons for two relay using MQTT (0 Replies)
- KC868-A32 I2C communication with arduino (5 Replies)
- KC868-A32 Shutter with percentage (2 Replies)
- Connection to the Home Assistant app? (24 Replies)
- Relay type - Can I use DC? (1 Reply)
- Rated power (1 Reply)
- Kc-868-a32 uart (3 Replies)
- KC 868-A32 (2 Replies)
- A32PRO - multiple 1-wire (1 Reply)
- KC 868-A32 (3 Replies)
- Kincony A32 Pro - Remove tuya Pairing (1 Reply)
- COM problem on A32 Pro (1 Reply)
- Kc868-a32 spi (1 Reply)
- KC868-A32 ESP32 I/O pin define (3 Replies)
- A32 Pro ESPHome yaml include RS485 modbus temperature humidity sensor (23 Replies)
- HTTP commands (2 Replies)
- A32 pro - 50x ds18b20 (1 Reply)
- KC868-A32 wiring diagram (11 Replies)
- kbox connectivity (3 Replies)
- Set up KC868-A series board (1 Reply)
- tank sensor (1 Reply)
- KC868 A32 Firmware 2.2.4 binding (2 Replies)
- A32 pro and traditional switch (1 Reply)
- DHT22 with A32PRO (5 Replies)
- how to slove A32 Pro/A24 DAC dimmer output voltage is not linear issue (0 Replies)
- A32 PRO RF433 (4 Replies)
- A32 Pro flash KCS_KC868_A32_V2.2.2.bin did not work (1 Reply)
- Problem With Ethernet Port (3 Replies)
- A32 RRO -homeassistanbt-Tuya-SIM-RF (11 Replies)
- A32 PRO Infrared (1 Reply)
- New Energy Board House (1 Reply)
- NTC 10KOHM temperature sensor (1 Reply)
- Kincony KC868-A32 Pro 250V / 7A (1 Reply)
- GND input (2 Replies)
- Tuya IoT platform parameter for A32 Pro controller (0 Replies)
- How to use tasmota for KC868-A32 via PCF8574 IIC extend GPIO (10 Replies)
- Arduino source code for A32 Pro - UDP with Ethernet chip W5500 (0 Replies)
- [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server (16 Replies)
- kc868-a32 ethernet problems (14 Replies)
- KC868-A32 relay board Loxone integration (1 Reply)
- Extra questions (4 Replies)
- [Arduino code for KC868-A32 Pro]-04 dubug 4G module AT command using serial port (0 Replies)
