Full Version: Development
Development
Pages: 1 2 3
Threads
  1. USING global VARIABLE IN yaml code (1 Reply)
  2. KC868-meter-7pv-rs485 (5 Replies)
  3. KC868-UAIR+BME-680 BSEC (22 Replies)
  4. ESP32+LD2410 presence sensor (8 Replies)
  5. Tasmota supported devices (3 Replies)
  6. ks868H32BS ks868COLB (9 Replies)
  7. KC868-H32B Pro - Node-Red on Home Assistant debug message every 2 second (21 Replies)
  8. Firmware problem KC868-E16S (5 Replies)
  9. KC868-AG - Tasmota firmware - cant read ir remote data (1 Reply)
  10. KC868-A8, Settimino, connection to Siemens PLC (3 Replies)
  11. Node-Red-flows for KC868-Hx relay controller with AWS EC2 Cloud Server (17 Replies)
  12. Display Relay Status on NodeRed (45 Replies)
  13. COLB update state in Home Assistant (6 Replies)
  14. i need help how to use tcp feedback node to update relay state (5 Replies)
  15. KC868-A8S - Trying to connect with GSM (1 Reply)
  16. KC 868 AG - YAML Code (4 Replies)
  17. Node-Red-flows for KC868-COL with AWS EC2 Cloud Server (12 Replies)
  18. KC868-H32BS Switch press delayed update (9 Replies)
  19. how to make android app from website by android studio (3 Replies)
  20. KC868-H32BS integrate to apple homekit by Node-Red (0 Replies)
  21. Understand Configuration For Own Software (46 Replies)
  22. how to send command and debug with KC868-COLB by yourself (1 Reply)
  23. integrate home assistant by http url command sample (2 Replies)
  24. How to use TCP Server and TCP Client work mode for your own software (0 Replies)
  25. Kincony Controller Application "AND/"OR" Statement (5 Replies)
  26. home assistant demo case for KinCony relay controller and dimmer (0 Replies)
  27. KBOX-Pad for Windows PC or Windows Tablet 10 inch (15 Replies)
  28. KC868-HxB relay controller MQTT protocol command (0 Replies)
  29. Home Assistant 8-Channel Smart Dimmer – KC868-D8 MQTT Firmware (1 Reply)
  30. uee web browser to control KinCony's device for development ways (0 Replies)
  31. Node-Red-flows for KC868-H32BS RS485 Modbus Demo (0 Replies)
  32. Unable to Connect using the Application KC868-H32 (3 Replies)
  33. UrsAI2MQTT extension for MIT APP INVENTOR (0 Replies)
  34. Transfer our own binaries to the system? (15 Replies)
  35. MulitiBoardCtrl software for KC868 visual studio C# source code (0 Replies)
  36. development code will get online store 10-100USD coupon (1 Reply)
  37. k868 COL and Domoticz (13 Replies)
  38. MIT App Inventor code for KC868 relay controller (0 Replies)
  39. Turn OFF 1st Pump and Turn "ON" pump interval (1 Reply)
  40. Node-Red-flows for KC868-D8 dimmer with AWS EC2 Cloud Server (0 Replies)
  41. Node-Red-flows for KC868-G WiFi gateway with AWS EC2 Cloud Server (0 Replies)
  42. Node-Red-flows for KC868-Hx relay control by USB-RS232 cable (0 Replies)
  43. Update kc868 col (1 Reply)
  44. KC868-COL - Wireless LED DI Status (2 Replies)
  45. Color change on Measure Bar (5 Replies)
  46. How to connect H8W with Outside network (7 Replies)
  47. How to integrate KC868 Controller to your software platform (0 Replies)
  48. NodeRed Dashboard Layout of Icons (3 Replies)
  49. How to integrate KinCony's product in your own software platform? (0 Replies)
  50. Unable to Turn "Off" or "ON" via KC868 CON and 32 Relay board Controller via RS232 (11 Replies)
Pages: 1 2 3
