KC868-AIO
Threads
- 4 - 20 mA adc not giving correct values (3 Replies)
- OUTPUT DO1 (8 Replies)
- Modifying analog Inputs (9 Replies)
- AIO pins 0-5v reading 3.150v (12 Replies)
- Soil moisture sensors (10 Replies)
- KC868-AIO ESP32 I/O pin define (10 Replies)
- access control panel input number control OUTPUT by wiegand yaml for ESPhome (0 Replies)
- Connect DS18b20 temperature sensor to KC868-AIO (9 Replies)
- Interfacing WS2812B led strips (3 Replies)
- KC868-AIO LOXONE (9 Replies)
- Screw-in terminal replacements for push-in ones (11 Replies)
- KC868-AIO configure yaml for ESPhome (25 Replies)
- DS18B20 longer distance (6 Replies)
- KC868-AIO connecting to ESPHome (1 Reply)
- Temp Sensors (1 Reply)
- Interfacing multiple LED strips to the AIO board (1 Reply)
- AIO board has failed (8 Replies)
- 4-20mah sensor wiring example (3 Replies)
- KC868-AIO User guide and other docs (1 Reply)
- Control fan speed using 0-10V and SSR (4 Replies)
- Dallas Temp Sensor (14 Replies)
- KC-868 AIO (1 Reply)
- Home Assistant ESP home AIO firmware update failed (6 Replies)
- AIO input 8 stuck on (7 Replies)
- I/O naming in Home Assistant (2 Replies)
- [Arduino source code for KC868-AIO]-07 PWM_ALL_ON AND OFF (2 Replies)
- Issue with KC868-AIO-EXTAO--V1.2 (9 Replies)
- AIO connection rs485 modbus temperature humididty sensor (2 Replies)
- KC868-AIO circuit diagram (0 Replies)
- KC868-AIO source code (3 Replies)
- Ethernet communication failures (5 Replies)
- AIO config yaml for home assistant integration by KCS mqtt (1 Reply)
- No ethernet available (5 Replies)
- serial rx/tx and rs485 A/B (1 Reply)
- KC868-AIO datasheet PDF (0 Replies)
- [Arduino source code for KC868-AIO]-08 DIGITAL_INPUT (0 Replies)
- [Arduino source code for KC868-AIO]-06 RS485 (0 Replies)
- [Arduino source code for KC868-AIO]-05 DIGITAL_OUTPUT (0 Replies)
- [Arduino source code for KC868-AIO]-04 ADC (0 Replies)
- [Arduino source code for KC868-AIO]-03 ETHERNET (0 Replies)
- [Arduino source code for KC868-AIO]-02 DS3231_RTC (0 Replies)
- [Arduino source code for KC868-AIO]-01 DS18B20 (0 Replies)
