Full Version: KC868-A16S
KC868-A16S
Threads
  1. DS3231 RTC module (4 Replies)
  2. KC868-A16S GSM/LTE Connection Issue - CSQ=99 (No Signal) (1 Reply)
  3. KC868-A16S configure yaml for ESPhome (23 Replies)
  4. Modbus RS485 in Esphome (1 Reply)
  5. No output DO1-DO16 (2 Replies)
  6. IIC header (3 Replies)
  7. KC868-A16S Arduino Issue (4 Replies)
  8. How to configure HTTP post for Webhook (0 Replies)
  9. KC868-A16S SMS Control issue (1 Reply)
  10. LAN port randomly freezing (9 Replies)
  11. KC868-A16S analog input (2 Replies)
  12. KC868-A16S multiple DS18B20 possible ? (1 Reply)
  13. KC868_16S System Menu : exit to login (2 Replies)
  14. Problem in output relay (3 Replies)
  15. how to use one click , double , holed click for automation esphome (7 Replies)
  16. Accessible SPI interface? (1 Reply)
  17. KC868-A16S and ds18b20 (1 Reply)
  18. rs485 port with kc868-a16s. (3 Replies)
  19. Tuya Controller (2 Replies)
  20. ESP boad (1 Reply)
  21. M30 Pulse Input (7 Replies)
  22. KC868-A16S Paired Inputs (5 Replies)
  23. KC868-A16S power info (3 Replies)
  24. Errno 113 (5 Replies)
  25. Advise me on the simplest (1 Reply)
  26. lost access to my module’s interface with IP address (7 Replies)
  27. Tuya app by ESPHome in KC868-A16S (1 Reply)
  28. KC868-A16S & Tuya & Alexa (3 Replies)
  29. connecting sensors to the KC868-A16S module (5 Replies)
  30. Ethernet update (3 Replies)
  31. Integration with HA original FW (3 Replies)
  32. Tuya kc868-a16s & kc868-h32b pro with rs485 (5 Replies)
  33. [Arduino source code for KC868-A16S]-02 PCF8574-OUTPUT (3 Replies)
  34. gas pressure sensor (4 Replies)
  35. KC868-A16S wiring diagram (1 Reply)
  36. KC868-A16S ESP32 I/O pin define (2 Replies)
  37. how instal firmware. (13 Replies)
  38. i want copy of KCS FIRMWARE FOR A16S (5 Replies)
  39. KCK-A16S give ethrnet failed to connect (3 Replies)
  40. [Arduino source code for KC868-A16S]-06 DS18B20 (0 Replies)
  41. [Arduino source code for KC868-A16S]-05 LAN8720_UDP (0 Replies)
  42. [Arduino source code for KC868-A16S]-04 ADC_code (0 Replies)
  43. [Arduino source code for KC868-A16S]-03 433_DECODE (0 Replies)
  44. [Arduino source code for KC868-A16S]-01 PCF8574-INPUT (0 Replies)
