Full Version: KC868-M16 / M1 / MB / M30
Threads
  1. CT Clamp Compatibility (12 Replies)
  2. M16v2 and SCT013-050 (5 Replies)
  3. M30 Power Factor (1 Reply)
  4. m16v2 energy meter - calibration issues (13 Replies)
  5. Expand/Chain M30 (3 Replies)
  6. MB Current & Power too low. (3 Replies)
  7. Faulty Kincony MB (1 Reply)
  8. How Watt Measurement Works (1 Reply)
  9. KCS M1 Firmware? (Kincony M1) (5 Replies)
  10. how to test M30 by web server firmware (3 Replies)
  11. M30 - Inrush power recording (1 Reply)
  12. M30 CTs for Industrial Loads (3 Replies)
  13. M30 new yaml (0 Replies)
  14. AC voltage and calibration (35 Replies)
  15. M30 isn't working properly? (4 Replies)
  16. M30 Extension MODBUS RTU Controller (2 Replies)
  17. Question: Can I Get kWh Values with 0.01 Resolution Instead of 1 kWh? (1 Reply)
  18. M30 30A DC monitoring with CT? or RS485 to another device? (3 Replies)
  19. Clarification on CT Clamp Sensor Input Assignments for Split-Phase Monitoring (3 Replies)
  20. Suitable CT clamps for M30 (23 Replies)
  21. Issues with Ethernet connection (7 Replies)
  22. M30 CT ratio (5 Replies)
  23. MB Specs - 8A per channel? variable voltage per channel? (8 Replies)
  24. M30 negative power (3 Replies)
  25. kc868 M16-V2 (19 Replies)
  26. M30 ESP32 I/O pin define (7 Replies)
  27. KC868-M30 - how to get it to work (4 Replies)
  28. M16v2 (1 Reply)
  29. Recording of energy usage data on M30 to MicroSD (5 Replies)
  30. KC868-M1 ESP32 I/O pin define (3 Replies)
  31. M16 Warning: Component <unknown> took a long time for an operation (3 Replies)
  32. add M30 to home assistant "Energy" dashboard (2 Replies)
  33. Basic Steps to Connect MB to Home Assistant (5 Replies)
  34. M16 SHT31 sensor disconnected (4 Replies)
  35. C++ application for KC868_M16v2 (1 Reply)
  36. M30 - Jumpers for CT inputs (voltage/mA) (6 Replies)
  37. M16 Incorrect current reading (1 Reply)
  38. M30 Troubles (4 Replies)
  39. Energy consumption not measured (2 Replies)
  40. M30 energy consumption not measured (1 Reply)
  41. M30 does not correctly read power and energy (22 Replies)
  42. complete code Arduino IDE for M16 (6 Replies)
  43. CT Clamp small for 25am (11 Replies)
  44. MQTT M16v2 (1 Reply)
  45. M30 Specifications (5 Replies)
  46. m30 rs485 compatible energy meter (15 Replies)
  47. Test KinCony M30 board data using high-precision power supply (0 Replies)
  48. Reboot M30 Remotely (1 Reply)
  49. EnEnergy calculation on M30 (3 Replies)
  50. M30 RS485 and Serial port development guide (12 Replies)
