Extender module
Threads
- E8v3 E16v3 E24v3 relay module ARM CPU firmware (0 Replies)
- KinCony ESP32-S3 Core Board ESPHome yaml for home assistant (43 Replies)
- RS485 TS sensor with A16v3 esphome yaml (0 Replies)
- TR connect with DHT11 sensor (0 Replies)
- smoke sensor user manual (0 Replies)
- gas sensor user manual (0 Replies)
- temperature humidity sensor convertor – TR ESP32 Pin define (1 Reply)
- PCF8574 IO Expansion i2c relay board -DO8 ESPHome config yaml demo (4 Replies)
- temperature humidity sensor convertor – TR RS485 Modbus protocol (0 Replies)
- PCF8574 IO Expansion i2c digital input board -DI8 ESPHome config yaml demo (2 Replies)
- how to use HAv2 RS485 switch adapter work with E16S relay board (0 Replies)
- smoke sensor pin define (0 Replies)
- Presence Sensor Remote Control User Manual (0 Replies)
- Issues with KinCony ESP32-S3-WROOM-1U N16R8 Core Development Board (3 Replies)
- RS485 Temperature and Humidity Sensor Modbus RTU (17 Replies)
- KinCony TS Tiny sensor PC software and modbus protocol (0 Replies)
- ESP32 S3 set up issue (10 Replies)
- wired temperature and humidity sensor pin define (0 Replies)
- wired gas sensor pin define (0 Replies)
- PCF8574 IO Expansion i2c relay board -DO8 arduino demo code (2 Replies)
- Like the A6 but more 0-10V outputs (6 Replies)
- Modbus (0 Replies)
- ATF Arduino source code - Save DS18B20 Temperature Data on a micro SD Card by Excel (0 Replies)
- KinCony ATF SD module PCB size details PDF (0 Replies)
- KinCony ESP32-S3 Core Board pin defines (0 Replies)
- KinCony ATF (ESP32 SD card module) print information arduino demo code (0 Replies)
- KinCony ATF (ESP32 SD card module) Read/Write arduino demo code (0 Replies)
- KinCony ATF (ESP32 SD card module) ESPHome yaml for home assistant (0 Replies)
- KinCony ATF (ESP32 SD card module) pin defines (0 Replies)
- PCF8574 IO Expansion i2c relay board -DO8 schematic (0 Replies)
- PCF8574 IO Expansion i2c digital input board -DI8 arduino demo code (0 Replies)
