KC868-A series and Uair Smart Controller
Threads
- Relay board wiring error? (3 Replies)
- flash kc868-a4 (21 Replies)
- how to compile new tasmota firmware by simplest way (5 Replies)
- Debuter avec KC868-A16 v1.66 (3 Replies)
- Kc868a newbie questions (5 Replies)
- Board output not responding to input commands (3 Replies)
- kincony a16 modbus + WallPad wall switch (1 Reply)
- easy way to export/import everything from ESP32 - CLONE/BACKUP Tool (7 Replies)
- SSD1306 not working at same time as pcf8574 (1 Reply)
- KC868-A16 verison with N-channel MOSTFETS in DO (1 Reply)
- flash KC868-A16 (7 Replies)
- Kc868-A16 (7 Replies)
- KC868-A6 case 3D model (5 Replies)
- KC868-A8v3 ModBus Temp. Sensor (1 Reply)
- kc868 pzem017 18b20 (10 Replies)
- IIC Connector type (1 Reply)
- IIC Not working (4 Replies)
- KC868-A16 Rev V1.6: Second PCF8574 Inputs/Outputs Not Working (3 Replies)
- More than 3 DHT11 Sensors GPIO connection (7 Replies)
- KC868-A16 LED Output (7 Replies)
- Kc868-A8 and short time for relay (1 Reply)
- 868-a16 or a32 Poe question (3 Replies)
- KC868-V16 and 6-terminal PIR Wiring (2 Replies)
- KC868 A16 Tasmota (15 Replies)
- trying to flash the kc868 A16 (3 Replies)
- Change PIN define (1 Reply)
- Where are the pins led out? (3 Replies)
- KC868-A16 integrates Home Assistant via MQTT? (1 Reply)
- Wired Temperature Protector Sensor (8 Replies)
- esphome 2026.01 the configuration of ethernet (3 Replies)
- KC868-A8V3 and ESPHome firmware (4 Replies)
- KC868-A and ds18b20 (9 Replies)
- KC868-A32 and EspEasy firmware (2 Replies)
- Lesson31- How to decode 433MHz RF signal and control RF device by ESPHome (17 Replies)
- KC868-A8 TCP -Server (25 Replies)
- KC868-A2/A4S Tuya IoT (1 Reply)
- UART2 (2 Replies)
- Kc868-a32 lcd_pcf8574 esphome yaml example (4 Replies)
- KC868-A16v3 more 1Wire Temp-Sensor per Pin (5 Replies)
- Notes on using the DHT22 (2 Replies)
- R503 do'nt scan fingerprints (5 Replies)
- KC868-A16 + 2 × R4DCB08 – CRC errors (1 Reply)
- KC868-A16 detected but failed to download firmware (3 Replies)
- A32 Pro Cross-Controller Control (7 Replies)
- KC868-AIO question (6 Replies)
- KCS868-A6 not found (22 Replies)
- KC868-AG and RF projector screen (1 Reply)
- KC868 A16 and ESP32 Ulp (1 Reply)
- A32 for blinds - KCS firmware question/issues (3 Replies)
- KC868-a6-v1.3sp + 0.5V Analog Input (2 Replies)
