Full Version: KC868-A series and Uair Smart Controller
Pages: 1 2 3 4 5 6
Threads
  1. a16 feedback (7 Replies)
  2. IR Receiver Compatibility with KC868-A6 and KC868-A16 (1 Reply)
  3. IR Receiver Compatibility with KC868-A6 and KC868-A16 (1 Reply)
  4. questions! (17 Replies)
  5. Something is wrong on product detail image of KC868-A8 (5 Replies)
  6. KC868-A8 v1.5 PIR AM312 (9 Replies)
  7. KC868-A16 to steer a 24V AC circuits (5 Replies)
  8. KCS firmware - MQTT LWT? (35 Replies)
  9. What makes the ESP32 chip better over the older ESP8266? (0 Replies)
  10. A16 and HC-SR04 (1 Reply)
  11. KCS: Add ability to turn off saving output state to NVS? (7 Replies)
  12. A64 turn off (1 Reply)
  13. A16 -> TX RX pins (1 Reply)
  14. A128 and B32Pro (5 Replies)
  15. KCS firmware (14 Replies)
  16. Lesson23- How to connect RGB LED strip using ESP32 by KC868-A4 A8 (18 Replies)
  17. using KC868-A16 ESP32 relays at 220v (1 Reply)
  18. KC868-A16 & ds18b20 (11 Replies)
  19. KC868-A6 DS1307 Issue (20 Replies)
  20. PIR Sensor A6 (1 Reply)
  21. how to check PCF8574/PCF8575 i2c address (0 Replies)
  22. Pulse Counter Sensor (0 Replies)
  23. KC868-A16S or KC868-A8S (5 Replies)
  24. KC868 A6 User Guide (11 Replies)
  25. communication with I2C sensor (3 Replies)
  26. KC868-A16 esp32 board (A16)as upgrade of a Homevision Controller? (36 Replies)
  27. Lesson20- how to use PCF8574 IIC extend GPIO for ESP32 input ports (2 Replies)
  28. Kinkony A24. Digital input (5 Replies)
  29. Help with KC868-A8 and traditional wall switch (8 Replies)
  30. Lesson18- how to use UDP communication with KC868-A8 by ethernet (4 Replies)
  31. KC868-AI TCP COMUNICATION PROTOCOL (1 Reply)
  32. kc868_A8: NodeMCU-32s, 80Mhz, 115200. None. Disabled sur COM4. (9 Replies)
  33. KC868-A8S v2 manufacture issue? print issue? Tasmota issue? (1 Reply)
  34. Technical consultation connection KC868-A16 (18 Replies)
  35. Tuto for NOOBS (1 Reply)
  36. 1wire stopped working - KC868-A8 (7 Replies)
  37. how to replace ESP32 large memory module for KinCony ESP32 Controller (0 Replies)
  38. Error on ESPHOME Official Config? (5 Replies)
  39. Problem uploasing esphome firmware to KC868-A16 (3 Replies)
  40. KC868-AI - from Alarm panel (1 Reply)
  41. KC868-A16S Analog input 4-20mA convert not linear (3 Replies)
  42. KC868-A8 + KCS + iiC + PCF8574 + TUYA (3 Replies)
  43. KC868 AK (3 Replies)
  44. KC868-A8 - Possible to use A1 and A2 as standard inputs? (1 Reply)
  45. KC868-A16S Analog input 4-20mA connection (4 Replies)
  46. output turns off automaticly (1 Reply)
  47. No Response (3 Replies)
  48. Smoke Sensor Connected to KC868-AI (1 Reply)
  49. RS485 Light Switch (7 Replies)
  50. Kc868-AK (3 Replies)
Pages: 1 2 3 4 5 6
