KC868-A series and Uair Smart Controller
Threads
- KC868-HAv2 (1 Reply)
- KC-868-A8 analog output 0-10v (1 Reply)
- KC868 AI (9 Replies)
- Help to choose the right board (3 Replies)
- Two IFTT on same Input (1 Reply)
- KC868-A64 REV 1.3 - Ethernet is not Working (3 Replies)
- Retrofitting an RTC battery on the I2C bus in the KC858-A-8 V1.6 panel (2 Replies)
- KC868-A* Default Firmware (1 Reply)
- KC868-A8 only with standard tasmota firmware possible (6 Replies)
- KC868-A16 HTTP requests? (4 Replies)
- dry contact k868 a8m (5 Replies)
- PT1000 to KC868-A8 by ADC (8 Replies)
- ZP13 Smoke Gas Sensor Module (1 Reply)
- KC868-A8 Help (5 Replies)
- KC868-A8 PH and ORP sensor (3 Replies)
- KC868-A2 SIM7600 (1 Reply)
- KC868-A8 Useless Opto on input? (1 Reply)
- ws2812 led digital strip or similar (1 Reply)
- kc868-a2 SIM7600 (6 Replies)
- KC868-A64 output changes are slow (7 Replies)
- KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome (51 Replies)
- Power supply for KC868-A8 (DRC-60) (3 Replies)
- KC868-A32M vs KC868-A16 (1 Reply)
- A16 flash problem (26 Replies)
- KC868-A6 Tasmota HA (3 Replies)
- KC868-A8 max6675 (1 Reply)
- KC868-AG RF not working (7 Replies)
- kc868-ak and button switch (4 Replies)
- [KC868-AG PRO] Tuya and scenes (14 Replies)
- Relay selection (18 Replies)
- KC868-A64 from box problems (4 Replies)
- My questions about KC868-H32B PRO? (1 Reply)
- error instal A128 (15 Replies)
- Questions regarding KC868-A8 (9 Replies)
- KC868-A8 Inputs (11 Replies)
- Power supply via UPS, leakage sensor, other UART devices (3 Replies)
- [KC868-AG] IR not working (9 Replies)
- KC868-A16 NC outputs (1 Reply)
- KC868-A8 - question regarding safety shutdown (5 Replies)
- Lesson28- How to use KC868-A4 (ESP32) DAC output DC 0-10V by ESPHome (9 Replies)
- KC868_A64 (9 Replies)
- can I connect A8S to Touchscreen by TTL Serial connection (3 Replies)
- How can I use Interrupt ? (5 Replies)
- [KC868-A16] Problem with PCF8574 I/O (3 Replies)
- [KC868-A16] Can't turn status leds on through HomeKit (6 Replies)
- Using two PCF8574s for DI and DO (1 Reply)
- KinCony KC868-AP Modbus using in Esphome not working (1 Reply)
- KC868-Uair (1 Reply)
- Does your device support the frequency measurement mode at the Digital Input pin? (1 Reply)
- Rebooting Core 0 panic'ed (LoadProhibited). Exception was unhandled. (1 Reply)
