Full Version: KC868-A series and Uair Smart Controller
Pages: 1 2 3 4 5 6
Threads
  1. KC868-16A crashing in infinite loop (11 Replies)
  2. B24M: Need help connecting a wall switch to control MOSFET output (1 Reply)
  3. Analoge input for door sensors? (1 Reply)
  4. KC868-A16S: Can ESP32 read the manual control extender buttons? (1 Reply)
  5. Connecting Nextion NX3224K028 HMI display to KC868-A16S? (3 Replies)
  6. KC868-A16 v1.6 – relays 9–16 not working in ESPHome (1 Reply)
  7. KC868-A4 USB not detected by computer (4 Replies)
  8. A8 brick (3 Replies)
  9. SSD1306 not working at same time as pcf8574 (7 Replies)
  10. PinOut AOI KC868-A8V3 (1 Reply)
  11. KC868-A16 UART pins (1 Reply)
  12. Alarm system wiring (6 Replies)
  13. Where are the pins led out? (5 Replies)
  14. Kincony A-128 – Digital Output LEDs glowing when OFF + module freezes when switching (3 Replies)
  15. Relay board wiring error? (3 Replies)
  16. flash kc868-a4 (21 Replies)
  17. how to compile new tasmota firmware by simplest way (5 Replies)
  18. Debuter avec KC868-A16 v1.66 (3 Replies)
  19. Kc868a newbie questions (5 Replies)
  20. Board output not responding to input commands (3 Replies)
  21. kincony a16 modbus + WallPad wall switch (1 Reply)
  22. easy way to export/import everything from ESP32 - CLONE/BACKUP Tool (7 Replies)
  23. KC868-A16 verison with N-channel MOSTFETS in DO (1 Reply)
  24. flash KC868-A16 (7 Replies)
  25. Kc868-A16 (7 Replies)
  26. KC868-A6 case 3D model (3 Replies)
  27. KC868-A8v3 ModBus Temp. Sensor (1 Reply)
  28. kc868 pzem017 18b20 (10 Replies)
  29. IIC Connector type (1 Reply)
  30. IIC Not working (4 Replies)
  31. KC868-A16 Rev V1.6: Second PCF8574 Inputs/Outputs Not Working (3 Replies)
  32. More than 3 DHT11 Sensors GPIO connection (7 Replies)
  33. KC868-A16 LED Output (7 Replies)
  34. Kc868-A8 and short time for relay (1 Reply)
  35. 868-a16 or a32 Poe question (3 Replies)
  36. KC868-V16 and 6-terminal PIR Wiring (2 Replies)
  37. KC868 A16 Tasmota (15 Replies)
  38. trying to flash the kc868 A16 (3 Replies)
  39. Change PIN define (1 Reply)
  40. KC868-A16 integrates Home Assistant via MQTT? (1 Reply)
  41. Wired Temperature Protector Sensor (8 Replies)
  42. esphome 2026.01 the configuration of ethernet (3 Replies)
  43. KC868-A8V3 and ESPHome firmware (4 Replies)
  44. KC868-A and ds18b20 (9 Replies)
  45. KC868-A32 and EspEasy firmware (2 Replies)
  46. Lesson31- How to decode 433MHz RF signal and control RF device by ESPHome (17 Replies)
  47. KC868-A8 TCP -Server (25 Replies)
  48. KC868-A2/A4S Tuya IoT (1 Reply)
  49. UART2 (2 Replies)
  50. Kc868-a32 lcd_pcf8574 esphome yaml example (4 Replies)
Pages: 1 2 3 4 5 6
