Full Version: B16M
B16M
Threads
  1. Cant flash esphom (1 Reply)
  2. RE: Problem selecting the output pin using smartlife app (1 Reply)
  3. Problem flashing firmware (12 Replies)
  4. HTTP GET api control (4 Replies)
  5. B16 MQTT & HA 2025.7 (4 Replies)
  6. RS485 in Home Assistant / B16 / KC868-HAV2 (7 Replies)
  7. B16M ESP32-S3 IO pins define (2 Replies)
  8. BM16 Problems (2 Replies)
  9. A32 pro lost control (3 Replies)
  10. Using B16M for driving LED strips (3 Replies)
  11. B16M 4-20ma pressure sensor input (4 Replies)
  12. adding rs485 device to B16M (2 Replies)
  13. Default firmware (5 Replies)
  14. Max PWM frequency (16 Replies)
  15. PWM output (3 Replies)
  16. [question]Max current in 12V DC (3 Replies)
  17. B16M ESPHome yaml for home assistant work with Tuya app (0 Replies)
  18. [arduino code examples for B16M]-10 Print TEXT on SSD1306 OLED displayer (2 Replies)
  19. [arduino code examples for B16M]-11 digital INPUT trigger OUTPUT directly (0 Replies)
  20. [arduino code examples for B16M]-09 how to communication with Tuya WiFi module (0 Replies)
  21. [arduino code examples for B16M]-08 Ethernet W5500 chip work with TCP Server mode (0 Replies)
  22. [arduino code examples for B16M]-07 how to DS3231 RTC clock (0 Replies)
  23. [arduino code examples for B16M]-06 How to use SD Card (0 Replies)
  24. [arduino code examples for B16M]-05 Read free GPIO state (0 Replies)
  25. [arduino code examples for B16M]-04 RS485 communication test (0 Replies)
  26. [arduino code examples for B16M]-03 Read ADS1115 analog input ports value (0 Replies)
  27. [arduino code examples for B16M]-02 Read digital input ports state (0 Replies)
  28. [arduino code examples for B16M]-01 Turn ON/OFF OUTPUT (0 Replies)
  29. B16M ESPHome yaml for home assistant with tuya (0 Replies)
