Full Version: F16
F16
Threads
  1. 24V Pulse input (3 Replies)
  2. F16 relay stopped functioning (7 Replies)
  3. sample code to receive http get (23 Replies)
  4. F16 Smart Controller Wiring Examples (0 Replies)
  5. F16 Smart Controller ESP32 system block diagram (0 Replies)
  6. F16 tuya reverse sw. function missing (5 Replies)
  7. F16 (1 Reply)
  8. Analog Inputs via MQTT HA Auto Discover (1 Reply)
  9. Powering a DS18b20 (2 Replies)
  10. F16 Support/warranty (1 Reply)
  11. KC868-E16v2 (3 Replies)
  12. Reset line via GPIO output to 24v Flow meter. (1 Reply)
  13. DI8 i2c io expander (5 Replies)
  14. 4-20ma Pressure transmitter (7 Replies)
  15. how to use F16 tuya app with analog sensor (0 Replies)
  16. Red or Green LED's (1 Reply)
  17. Electric heated floor + F16. (4 Replies)
  18. rs485 SHT (5 Replies)
  19. RF with KCS-firmware (1 Reply)
  20. Trigger LED on Wall Switch Panel (5 Replies)
  21. I may have fried my board (1 Reply)
  22. Usb config (3 Replies)
  23. F16 ESPHome yaml for home assistant without tuya (0 Replies)
  24. F16 ESPHome yaml for home assistant with tuya (8 Replies)
  25. [arduino code examples for F16]-02 Read digital input ports state (2 Replies)
  26. PCF8575 Library Missing for F16 (1 Reply)
  27. What is the expected relay behaviour? (1 Reply)
  28. Kincony F16 24v power (1 Reply)
  29. Kincony + Somfy LM100 (5 Replies)
  30. [arduino code examples for F16]-10 Print TEXT on SSD1306 OLED displayer (0 Replies)
  31. [arduino code examples for F16]-09 how to communication with Tuya WiFi module (0 Replies)
  32. [arduino code examples for F16]-08 Ethernet W5500 chip work with TCP Server mode (0 Replies)
  33. [arduino code examples for F16]-07 how to DS3231 RTC clock (0 Replies)
  34. [arduino code examples for F16]-06 How to use SD Card (0 Replies)
  35. [arduino code examples for F16]-05 Read free GPIO state (0 Replies)
  36. [arduino code examples for F16]-04 RS485 communication test (0 Replies)
  37. [arduino code examples for F16]-03 Read analog input ports value (0 Replies)
  38. [arduino code examples for F16]-01 Turn ON/OFF relay (0 Replies)
  39. F16 ESP32-S3 IO pins define (0 Replies)
