KC868-A16v3
Threads
- Z1 (14 Replies)
- Initial configuration for A16v3 (26 Replies)
- ESPHome installing issue (1 Reply)
- a16v3 - reed switch and motion sensor connection (17 Replies)
- RF doesnt show up? (2 Replies)
- Low Level Relay Trigger (5 Replies)
- KC868-A16v3 ESPHome yaml for home assistant (10 Replies)
- Low Level Output for Relays (1 Reply)
- Low Level Trigger for Relays (1 Reply)
- Automation lamps A16_V3+E16_V2 with traditional switch (8 Replies)
- json configuration file for platformio (3 Replies)
- GPIO numbers for Weigand (10 Replies)
- KC868-A16v3 Issue, No Display USB connection (3 Replies)
- KC868-A16v3 ESP32-S3 (3 Replies)
- KC868-HAv2 issue (1 Reply)
- A16v3 work with HAv2 ESPHome yaml (0 Replies)
- KC868-A16v3 ESP32-S3 IO pins define (14 Replies)
- 1-WIRE multiple sensors (1 Reply)
- Tasmota Template (4 Replies)
- Relay connection (5 Replies)
- Problem with ds18b20 on Port 1-3 (1 Reply)
- USB Cable (0 Replies)
- Problem with KC868-A16v3 + SCD41 (1 Reply)
- RF 433MHz Transmitter/Receiver range (3 Replies)
- MQTT Auto discovery problem (6 Replies)
- [arduino code examples for A16v3]-14 post data to mqtt topic (0 Replies)
- DS3231 battery (2 Replies)
- Kincony Cloud (1 Reply)
- Not able to upload arduino code to A16v3 board (10 Replies)
- a16v3 rf433 pins/other free pins for sim800l (1 Reply)
- [arduino code examples for A16v3]-08 Ethernet W5500 chip work with TCP Server mode (2 Replies)
- A16v3 cannot use multiple digital output on one load? (1 Reply)
- [arduino code examples for A16v3]-13 read DS18B20 temperature sensors (0 Replies)
- [arduino code examples for A16v3]-12 digital INPUT trigger OUTPUT directly (0 Replies)
- [arduino code examples for A16v3]-11 Print TEXT on SSD1306 OLED displayer (0 Replies)
- [arduino code examples for A16v3]-10 RF433MHz sender (0 Replies)
- [arduino code examples for A16v3]-09 RF433MHz decode (0 Replies)
- [arduino code examples for A16v3]-07 how to DS3231 RTC clock (0 Replies)
- [arduino code examples for A16v3]-06 How to use SD Card (0 Replies)
- [arduino code examples for A16v3]-05 Read free GPIO state (0 Replies)
- [arduino code examples for A16v3]-04 RS485 communication test (0 Replies)
- [arduino code examples for A16v3]-03 Read analog input ports value (0 Replies)
- [arduino code examples for A16v3]-02 Read digital input ports state (0 Replies)
- [arduino code examples for A16v3]-01 Turn ON/OFF OUTPUT (0 Replies)
