Full Version: N30
N30
Threads
  1. N30 most recent ESPhome (1 Reply)
  2. MQTT Discovery: missing state_class for power sensors in Home Assistant (2 Replies)
  3. N30 (KCS): energy counters of BL0910 #2 and #3 published as 0 kWh at boot (2 Replies)
  4. Current direction detection incorrect on channels 2 and 3 (5 Replies)
  5. Best way to read from N30 (3 Replies)
  6. Modbus 485 extender kcs V3 and lora and PCB eletechsup 10ioA12 (11 Replies)
  7. solar production and consomation (3 Replies)
  8. Can't make AC868-A6 V1.4Sp work with Arduino IDE (3 Replies)
  9. N30 power supply (3 Replies)
  10. Energy calculation for negative currents (4 Replies)
  11. Reset Total Energy only works per chip (1 Reply)
  12. N series Energy Meter for Loxone UDP Protocol (0 Replies)
  13. KCS update and ARM CPU update (2 Replies)
  14. kWh resolution (37 Replies)
  15. Voltage wrong (4 Replies)
  16. Which CT clamps for the N30 or other boards N10/N20 (3 Replies)
  17. N31 energy value integer values (1 Reply)
  18. N30 Energy entry not working and power entry is wrong (30 Replies)
  19. Problems and general Feedback (2 Replies)
  20. N30 LoRa and RS485 code for esphome (2 Replies)
  21. N30 installation for Home Assistant (13 Replies)
  22. N30 + KCS v3.15.0 firmware (4 Replies)
  23. N30 configure yaml for ESPhome (0 Replies)
  24. N60/N30/N20/N10 PC software for RS485 modbus connection (1 Reply)
  25. [arduino code examples for N30]-05 collect N30 all data demo (0 Replies)
  26. [arduino code examples for N30]-04 Print TEXT on SSD1306 OLED displayer (0 Replies)
  27. [arduino code examples for N30]-03 Ethernet W5500 chip work with TCP Server mode (0 Replies)
  28. [arduino code examples for N30]-02 How to use SD Card (0 Replies)
  29. [arduino code examples for N30]-01 Read digital input ports state (0 Replies)
  30. N30 ESP32 I/O pin define (0 Replies)
