04-04-2022, 12:20 PM
04-08-2022, 12:18 PM
(04-04-2022, 12:20 PM)admin Wrote: [ -> ]ok, when have development news, i will tell you.
any news ?
04-08-2022, 12:24 PM
developing, it need time.
04-19-2022, 01:21 AM
https://www.kincony.com/forum/showthread.php?tid=1843 here is sample code for WiFi mqtt. You can modify or update it.
04-20-2022, 05:49 AM
04-21-2022, 04:00 AM
Thanks for this tutorial.
I followed each and every step and It really worked.
10-22-2022, 05:48 PM
(11-15-2021, 01:24 AM)admin Wrote: [ -> ]Thanks for "blakadder" from https://blakadder.com supply the tasmota firmware BIN file for KC868-A8
details you can see : https://blakadder.com/kincony-KC868-A8
1. download tasmota firmware for KC868-A8
2. After you get it running on your Wi-Fi network, set the template in " Configuration - Other"
copy this code:
{"NAME":"KC868-A8","GPIO":[32,0,1120,0,640,608,0,0,0,1,1,1152,0,0,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,0,0,1,0,0,1],"FLAG":0,"BASE":1,"CMND":"EthClockMode 3 | EthAddress 0 | EthType 0 | I2CDriver2 1"}
3. After applying the template you need one more configuration step. Navigate to " Configuration - Configure PCF8574 " and set the PCF8574 connected to relays to Output.
hello friend, I have a doubt, with the tasmota installed, how can I activate the relays through the pulse input? I can only activate it through the app.
copy this code:
Olá pessoal , estou com uma dúvida , fiz todo processo mas não conseguir acionar os relés pela entrada de pulso , apenas pela web
10-22-2022, 11:11 PM
this rules sample will set KC868-A16 input1 toggle output1 : https://www.kincony.com/forum/showthread.php?tid=1792
you can use this way for KC868-A8, just create a rule.
04-25-2023, 08:14 AM
sto provando a far funzionare il firmware tasmota solo lan disattivando wifi,in un primo momento perdo la connessione poi dopo ore di non funzionare inizia a funzionare regolarmente
04-25-2023, 10:43 AM
maybe tasmota have some issue.
