But on logs console, I don't get any other ip address (only wifi address), and don't react when I plug/unplug ethernet cable
[11:47:53]00:00:00.002 HDW: ESP32-D0WDQ6
[11:47:53]00:00:00.065 UFS: FlashFS mounted with 304 kB free
[11:47:53]00:00:00.168 CFG: Loaded from File, Count 13
[11:47:53]00:00:00.184 QPC: Count 1
[11:47:53]00:00:00.321 BRY: Berry initialized, RAM used=3504
[11:47:53]00:00:00.344 BRY: no 'preinit.be'
[11:47:53]00:00:00.348 I2C: PCF8574 found at 0x22
[11:47:53]00:00:00.349 I2C: PCF8574 found at 0x24
[11:47:53]00:00:00.352 PCF: Total devices 2, PCF8574 output ports 8
[11:47:53]00:00:00.357 Project tasmota - Tasmota Version 10.0.0.3(tasmota)-2_0_1(2021-11-14T21:44:07)
[11:47:54]00:00:00.536 BRY: no 'autoexec.be'
[11:47:54]00:00:01.042 WIF: Connecting to AP1 IBR-IOT Channel 6 BSSId XXXXX in mode 11n as tasmota-DC2E30-3632...
[11:47:58]00:00:05.121 WIF: Connected
[11:47:59]00:00:05.382 HTP: Web server active on tasmota-DC2E30-3632 with IP address 192.168.10.112
[11:48:00]11:48:00.512 RSL: INFO1 = {"Info1":{"Module":"KC868-A8","Version":"10.0.0.3(tasmota)","FallbackTopic":"cmnd/DVES_DC2E30_fb/","GroupTopic":"cmnd/tasmotas/"}}
[11:48:00]11:48:00.527 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-XXXX","IPAddress":"192.168.10.112"}}
[11:48:00]11:48:00.531 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU"}}
[11:48:00]11:48:00.545 RSL: RESULT = {"POWER1":"OFF"}
[11:48:00]11:48:00.547 RSL: POWER1 = OFF
[11:48:00]11:48:00.550 RSL: RESULT = {"POWER2":"OFF"}
[11:48:00]11:48:00.552 RSL: POWER2 = OFF
[11:48:00]11:48:00.554 RSL: RESULT = {"POWER3":"OFF"}
[11:48:00]11:48:00.556 RSL: POWER3 = OFF
[11:48:00]11:48:00.559 RSL: RESULT = {"POWER4":"OFF"}
[11:48:00]11:48:00.561 RSL: POWER4 = OFF
[11:48:00]11:48:00.563 RSL: RESULT = {"POWER5":"OFF"}
[11:48:00]11:48:00.576 RSL: POWER5 = OFF
[11:48:00]11:48:00.578 RSL: RESULT = {"POWER6":"OFF"}
[11:48:00]11:48:00.580 RSL: POWER6 = OFF
[11:48:00]11:48:00.583 RSL: RESULT = {"POWER7":"OFF"}
[11:48:00]11:48:00.585 RSL: POWER7 = OFF
[11:48:00]11:48:00.587 RSL: RESULT = {"POWER8":"OFF"}
[11:48:00]11:48:00.589 RSL: POWER8 = OFF
[11:48:00]11:48:00.720 QPC: Reset
[11:48:05]11:48:05.445 RSL: STATE = {"Time":"2022-03-26T11:48:05","Uptime":"0T00:00:12","UptimeSec":12,"Heap":149,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":183,"MqttCount":0,"POWER1":"OFF","POWER2":"OFF","POWER3":"OFF","POWER4":"OFF","POWER5":"OFF","POWER6":"OFF","POWER7":"OFF","POWER8":"OFF","Wifi":{"AP":1,"SSId":"IBR-IOT","BSSId":"XXXXXXXXXX","Channel":6,"Mode":"11n","RSSI":100,"Signal":-41,"LinkCount":1,"Downtime":"0T00:00:06"}}
[11:48:05]11:48:05.488 RSL: SENSOR = {"Time":"2022-03-26T11:48:05","ESP32":{"Temperature":85.0},"PCF8574-1":{"D0":1,"D1":1,"D2":1,"D3":1,"D4":1,"D5":1,"D6":1,"D7":1},"PCF8574-2":{"D0":0,"D1":0,"D2":0,"D3":0,"D4":0,"D5":0,"D6":0,"D7":0},"TempUnit":"C"}
