01-05-2022, 08:06 AM
Code 5: //The demo code is LAN8720-UDP You can copy the code to your Arduino IDE
[attachment=528]
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR 0
#define ETH_POWER_PIN -1
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
WiFiUDP Udp; //Create UDP object
Serial.println();
Serial.println("Connected");
Serial.print("IP Address:");
if (packetSize) //if have received data
char buf[packetSize];
Serial.println();
Serial.print("Received: ");
Serial.println(buf);
Serial.print("From IP: ");
Serial.print("From Port: ");
Udp.print("Received: ");
Udp.endPacket(); //send data
