Full Version: KC868-A16 ESP32 I/O pin define
#define ANALOG_A1  36
#define ANALOG_A2  34
#define ANALOG_A3  35
#define ANALOG_A4  39
IIC SDA:4
IIC SCL:5
Relay_IIC_address 0x24
Relay_IIC_address 0x25
Input_IIC_address 0x21
Input_IIC_address 0x22
DS18B20/DHT11/DHT21/LED strip -1: 32
DS18B20/DHT11/DHT21/LED strip -2: 33
DS18B20/DHT11/DHT21/LED strip -2: 14
RF433MHz wireless receiver: 2
RF433MHz wireless sender: 15
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:16
TXD:13
(01-14-2022, 11:29 PM)admin Wrote: [ -> ]#define ANALOG_A1  36
IIC SDA:4
IIC SCL:5
#define ETH_ADDR        0
RS485:
RXD:16
TXD:13
Hi, I am new to Kincony and the Arduino IDE. Working on a Standalone smart home control with KBOX Smart
So, this is the complete I/O pin configuration I need to use in my Arduino Sketch to be able to run?
Do you have a diagram showing the above I/O's?
if you want to use KBOX phone app, you can download "KCS" firmware, so that can directly to use.
we have video tour about "KCS", you can see it on our YouTube channel.
Thanks for the reply, will check out the mentioned video.
What about my question regarding the I/O diagram and configuration?
Is it possible to get PWM signal from GPIOs marked as HT1, HT2 and HT3 to connect it to my dimmer? If so, what would be esphome configuration?
no, some specific pins can use for PWM, not any ESP32 pins. you need to check with ESP32 datasheet.
3V3
HT3 - ESP32: IO ??
HT2 - ESP32: IO ??
HT1 - ESP32: IO ??
GDN
(01-07-2025, 05:21 PM)Vall2KAS Wrote: [ -> ]3V3
HT3 - ESP32: IO ??
HT2 - ESP32: IO ??
HT1 - ESP32: IO ??
GDN
GPIO32
GPIO33
GPIO14
This board doesn't include a 12-volt relay. The specifications say it should connect 0.5A. My relays are 1.2W (0.1A). And they don't work. When I command one relay to turn on, it doesn't turn on and turns off. I disconnect the wires from the relay, and there's voltage on the wires. When I connect the wires to the relay, the output on the board goes out.
It's strange that when the output is off, the LED on the board lights up, but when it's on, it turns off.
