Full Version: KC868-H32BS v 1.44 x MQTT
Hello all right, I'm starting to integrate kc868-h32bs v1.44 via mqtt in home assistant v2021.12.10. However, when I check if the settings in the configuration.yaml file are correct.
Invalid config for [switch]: required key not provided @ data['platform']. Got None. (See /config/configuration.yaml, line 28).
upload your configuration.yaml content, now i don't know what problem with you.
also here is configuration.yaml guide for H32BS:
https://www.kincony.com/kc868-h32b-integ...-mqtt.html
Hi, I managed to solve it. I only put the configuration codes of an input and a relay, but when I completed all the code it worked. Thanks.
ok, you are welcome.
