Full Version: KC868-A ESP32 RGBW LED Stripe
Hey,
i'm searching for a solution to control warm white/cold white 24V stripes from KC868-A... (esp32). can you recommend something?
in the past i use H801 to control 24V stripes. But i want to control it over your kc868 board to have a direct connection from switch to lamp Wink
suggest use WS2812B LED strip, easy to control by ESP32. here is video tour: https://youtu.be/xptAHlOLV-w
but i dont want to use rgb. i want to use warmwhite and coldwhite 24V leds or RGBWW
only use for change brightness of LED?
yes.
here you can see a example how it is done with h801
https://esphome.io/cookbook/h801.html
i see. H801 use for RGB LED strip. i think you can use A4,A8,A16 any one for RGB LED strip, just the LED strip chip is WS28xx series. here is ESPHome support:
https://esphome.io/components/light/fastled.html
ok thank you. i ordered SK6812 24V. this should work. how many diiffertent stripes can i use? how many outputs are able to control different led stripes?
which product board you are using?
hi
light:
  - platform: neopixelbus
    type: RGBW
    pin: GPIO13
    num_leds: 44
    variant: SK6812
    name: "$device_verbose_name lightstrip"
i have a8 board. its not working properly.
on a normal esp32 i use gpio0 + ground and everything is ok. but on a8 the same setup is not working. maybe you can help me what i am doing wrong...
i use the right connector. s1 (gpio13?!) and gnd. gnd is connected to the gnd of my 24V power supply (like you did it in the video with a 5v power supply)
what's your RGBW led's gpio voltage level? 5V ? 3.3V ?
