Full Version: KC868-32BS -ve/ground output
I've about 15 shades operated by 12vdc board. Please take a look at the attached photo. The blue wires are the triggers for the different electric motors for the shades. When I connect the blue wires with 12VDC ground(-ve), the shade operates.  Is there a way to configure the H32BS to output ground/-ve 12vdc?
Thanks much
when connect with GND or -12V will work? 0v or -12v?
(03-03-2022, 12:17 AM)admin Wrote: [ -> ]when connect with GND or -12V will work?  0v or -12v?
Ground, this is completely 12vDC no AC at all. By -ve I was referring to ground (or floating ground), please look at the attached diagram
H32BS' MOSFET is output high level, if you want to output low level. you can let H32BS connect to KC868-E16, E16 relay's COM connect with Ground. when Turn ON relay, then output 0V.
(03-03-2022, 12:23 AM)admin Wrote: [ -> ]H32BS' MOSFET is output high level, if you want to output low level. you can let H32BS connect to KC868-E16, E16 relay's COM connect with Ground. when Turn ON relay, then output 0V.
Got it. Thanks
(03-03-2022, 12:31 AM)udayansarma Wrote: [ -> ]
Got it. Thanks
Tried it with E16 relays and it all worked. Thanks much
