Hi
I'm tyring to use a K868-Uair with ESPHome but I have some problems ! According at Kincony ducomentation it should GPIO32 and 33 to control RGB LEDs of bottom ring and vertical bar ! Unhappy these two GPIOs are doing exactly the same thing: control the ring only and only 3 LEDs of it
Someone has the proper GPIO configuration of that board ?
Noticed also that the Dallas temperature sensor is a chinese copy I think as it's 4/5° offset of other temperature sensors I have in the room
Code used so far in ESPHome for LEDs:
light:
- platform: neopixelbus
type: GRB
variant: WS2812X
pin: GPIO33
num_leds: 4
type: GRB
variant: WS2812X
pin: GPIO32
num_leds: 4
Thanks for help
Vincèn
platform: ESP32
ota:
password: "978e66f878ed5041b830cfb427393c79"
wifi:
ssid: "KinCony" # your wifi router ssid
password: "12345678" # your wifi password
ap:
ssid: "Kc868-Uair Fallback Hotspot"
password: "FbTxCLlbDvbO"
captive_portal:
# follow configure use for DS18B20 temperature sensor, SHT30 temperature and humidity sensor. WS2812B RGB LEDs.
sda: 4
scl: 16
# Example configuration entry
dallas:
- pin: GPIO27
update_interval: 15s
# Individual sensors
- platform: dallas
address: 0xC000000004D81528 # your DS18B20 address
name: "internal Temperature"
- platform: sht3xd
temperature:
name: "extend Temperature"
humidity:
name: "extend Humidity"
address: 0x44
light:
- platform: fastled_clockless
chipset: WS2812B
pin: GPIO32 # Pin Define connected with LED strip
num_leds: 4 #LEDs number
rgb_order: GRB
effects:
- addressable_rainbow: ##defined 7 effects styles
- addressable_color_wipe:
- addressable_scan:
- addressable_twinkle:
- addressable_random_twinkle:
- addressable_fireworks:
- addressable_flicker:
chipset: WS2812B
pin: GPIO33 # Pin Define connected with LED strip
num_leds: 1 #LEDs number
rgb_order: RGB
effects:
- addressable_scan:
(03-09-2022, 11:41 AM)admin Wrote: [ -> ] (03-09-2022, 09:34 AM)vincen Wrote: [ -> ]Hi
light:
type: GRB
variant: WS2812X
pin: GPIO33
num_leds: 4
type: GRB
variant: WS2812X
pin: GPIO32
num_leds: 4
Thanks for help
Vincèn
GPIO33 use for 1 LED
GPIO32 use for 4 LED
Thanks for code it works this way but it's using old RGB implementation mode of ESPHome
In fact the device has a hardware issue as one of the ring LED is wired with bar so only 3 LEDs of ring work together, the other one works with bar which kills the visual effect of the ring !! Are you aware of that problem on the device ??
![[Image: IMG_20220311_193517.jpg]](https://www.vincen.org/forums/kincony/IMG_20220311_193517.jpg)
(03-11-2022, 11:03 PM)admin Wrote: [ -> ]no, 4 LEDs work together with ring LED. another one LED is indepentant. here is diagram, you can see details.
Thanks for the schematics but it doesn't correspond with reality ! Have a look at my picture you can clearly one of the LED is not following the other ones on ring but the ones of bar
do you use my code directly? or changed something?
(03-12-2022, 01:44 PM)admin Wrote: [ -> ]do you use my code directly? or changed something?
I use your code nearly without modifications, here it is:
substitutions:
friendly_name: kincony-netatmo
web_server:
ota:
wifi:
networks:
- ssid: !secret wifi
password: !secret wifi_passwd
- ssid: !secret wifi_puppy
password: !secret wifi_puppy_passwd
ap:
ssid: $friendly_name
captive_portal:
reboot_timeout: 120min
#i2c:
# sda: 4
# scl: 16
# scan: true
# id: bus_a
dallas:
- pin: GPIO27
- platform: dallas
address: 0x0800000004680128
light:
chipset: WS2812B
rgb_order: GRB
effects:
- addressable_scan:
chipset: WS2812B
rgb_order: RGB
effects:
- addressable_scan:
