this rules sample will set KC868-A16 input1 toggle output1.
for example if input1 -- toggle --> output1:
rule1 on PCF8574-1_INP#D0=0 do power1 toggle endon
rule1 1
if input2 -- toggle --> output2:
rule2 on PCF8574-1_INP#D1=0 do power2 toggle endon
rule2 1
if input3 -- toggle --> output3:
rule3 on PCF8574-1_INP#D2=0 do power3 toggle endon
rule3 1
here are setting photos for sample rule1:
attachment=796]
attachment=797]
attachment=798]
attachment=799]
I'm getting a command error when adding additional rules e.g.
rule4 on PCF8574-1_INP#D3=0 do power4 toggle endon
rule4 1
(03-30-2022, 07:12 AM)admin Wrote: [ -> ]rule1-3 work well?
yes, rules 1,3, and 3 are ok.
I ended up creating just 2 rules like this:
rule1
on PCF8574-1_INP#D4=0 do power5 toggle endon
on PCF8574-1_INP#D5=0 do power6 toggle endon
on PCF8574-1_INP#D6=0 do power7 toggle endon
on PCF8574-1_INP#D7=0 do power8 toggle endon
rule1 1
rule2
on PCF8574-2_INP#D0=0 do power9 toggle endon
on PCF8574-2_INP#D1=0 do power10 toggle endon
on PCF8574-2_INP#D2=0 do power11 toggle endon
on PCF8574-2_INP#D3=0 do power12 toggle endon
on PCF8574-2_INP#D4=0 do power13 toggle endon
on PCF8574-2_INP#D5=0 do power14 toggle endon
on PCF8574-2_INP#D6=0 do power15 toggle endon
on PCF8574-2_INP#D7=0 do power16 toggle endon
rule2 1
It's ok now
Rule1
use one rule1 will be ok.
Is there a way to send a command over IP when an input is clicked?
Thankyou.
i have not tried this by tasmota, but if you can write arduino code, this function will be very easy to do.
