Before step 8 I suggest to add the setting of serial com in Arduino Tools->port, according to computer registered port.
ok, thanks for suggestion.
The IR codes are recognised for "NEC".
How do we proceed with other brands to learn their remotes codes?
Thank you for your trainings!
Hi
I can't find air condition Carrier in the lists and links , how i can find to change the code?
If i had big area that have 3 carrier units all 3 the same remote control how i can control each separately using one KC-868-AG that in the middle to control all 3 or individual?
For adding the control of home theater reciever remote control to home asistance and other multimedia units with different brand pls guide for those
I can provide the brand and model if need them.
(07-15-2022, 02:42 PM)ahmedk4444@yahoo.com Wrote: [ -> ]Hi
take a photo of your air conditioner , what brand you are using?
if you want control each air conditioner separately. beside every air conditioner place one KC868-AG, let one KC868-AG only send IR signla to one air conditioner, note the IR sender direction.
(07-15-2022, 04:15 PM)ahmedk4444@yahoo.com Wrote: [ -> ]For adding the control of home theater reciever remote control to home asistance and other multimedia units with different brand pls guide for those
if you use IR remote, any way: you not need to know the brand of your device, just learn IR remote's button you will use, decode the IR , save the IR, then create home assistant button using the learned IR code to send.
The Aircondition brand is Carrier, buy for each 1 AG exprnsive, shoud be a way to configure each air condition separetely with separate naminging and confihure individuly by thd coding then i can use with one AG in the area each one of identical Ac1,2,3 individully .
For multimedia learning each button is painful for AV reciver remote control more than 50 buttons, kmagine fir AV, projector, tv, blu ray, projrctor motorized screen etc.
