DS18B20 temperature range: -55°C to +125°C and is accurate to ±0.5°C
ESPHome config:
# Example configuration entry
dallas:
- pin: 4
update_interval: 5s
# Individual sensors
- platform: dallas
address: 0x69062162d9ec4328
attachment=847]
Please make a guide for homekit and how to use multiple temp sensors.
when have free time, can make it.
Hi , I want to connect DHT22 sensor but getting some error
code i am using
- platform: dht
pin: 3
temperature:
humidity:
name: "Living Room Humidity"
update_interval: 60s
error message i am getting
[18:12:11][D][api:102]: Accepted 192.168.1.13
[18:12:11][W][api.connection:083]: 192.168.1.13: Socket operation failed: HANDSHAKESTATE_READ_FAILED errno=11
[18:12:45][W][dht:169]: Requesting data from DHT failed!
[18:12:45][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number) and consider manually specifying the DHT model using the model option.
[18:12:45][D][sensor:094]: ‘Living Room Temperature’: Sending state nan °C with 1 decimals of accuracy
[18:12:45][D][sensor:094]: ‘Living Room Humidity’: Sending state nan % with 0 decimals of accuracy
wired connection
which board you are using?
(01-27-2024, 06:47 AM)admin Wrote: [ -> ]which board you are using?
KC868-Server
delete your device in ESPHome, re add it , maybe will solve it.
(01-27-2024, 12:11 PM)admin Wrote: [ -> ]delete your device in ESPHome, re add it , maybe will solve it.
it working now
1. Add the device with code in ESPHome
2. After Install - it will show online status in ESPhome
3. Setting >> Device&Service >> AddIntergration >> select ESPHome > and in hostname give ip add of sensor (in log file get the ip add - step 1)
4. Final - add encryption key (in step 2 open the device , copy the key) --- paste it and submit
(01-27-2024, 11:39 PM)admin Wrote: [ -> ]ok, good.
on KC868-E16s - Board -- which pin we can use for the Temperature sensor or other sensors ?
