Full Version: KC868-D8 Dimmer 1-10V, logarithmic
Hello
1. Is there any setting that I can use KC868-D8 dimmer as "1-10V"?
I have found a led driver din rail format (which would reduce the occupied space in my automation cabinet) but I need to work on 1-10V range instead of 0-10V.
example: https://www.sunricher.com/din-rail-0-1-1...ifications
2. I understand that KC868-D8 is a liniar driver; so in order to achieve a smooth logarithmic turn-on/off of light intensity I should combine it with a logarithmic led driver. please tell if I am wrong.
[Image: 1627051498-why-you-need-dimming-curves-6...q=60&w=300]
source: https://eldoled.com/insights/why-you-nee...ng-curves/
Thank you
1. if you can buy 0-10v output type is better, but if you only can find 1-10v driver, this also can be used, just KC868-D8 output will begin with 0v, the 0-1v range will do nothing for your driver, i think that range is LED will be OFF.
2. if turn ON/OFF use by wall switch connect to KC868-D8, turn ON will set brightness to 99, turn OFF will set brightness to 0. i think you not need to add the logical driver.
Dear SirĀ
Already We Development Code In ESP32. It's Possible To Edit My Code Abd Need To Add Some Future.
sorry, i don't understand you.
