06-01-2022, 07:25 AM
[attachment=1060]
ota:
password: "b9c07c109b7ecc6c63dac976c0c23a12"
wifi:
ssid: KinCony
password: xxxxxxxx
ap:
ssid: "A6 Fallback Hotspot"
password: "GLdHSsZr1p96"
captive_portal:
sda: 4
scl: 15
# Example configuration entry
# Individual outputs
pcf8574: pcf8574_hub_out_1
ota:
wifi:
ssid: KinCony
password: xxxxxxxx
ap:
captive_portal:
sda: 4
scl: 15
