Hello! Is it possible to connect COL and Domoticz?
now relay controller support use by Domoticz. COL not support.
will it be possible in future?
maybe, but now not have the plan.
Instead of domoticz can I connect COL with Home Assistant?
yes, no problem. home assistant is also easy to integration.
if you can write code, you can modify our relay controller's python source code for KC868-COL to use. that have share in our github.
Hello! Have some problems with import NODe_RED-COL file to home assistant!IT doesnt undestand some types - type of digital sensor and temperature/ i can fix it by your youtube video but there isnt discription for LEVEL box after temperature sensor. can you explain what I shold type there. or export correct node red file for current Home Assistant! thanx
Ps
And maybe you can post here you config.yaml for adding all this sensors?)
before import flows , you need install these nodes for Node-Red:
1. node-red-contrib-ui-led 【LED UI】
2. node-red-contrib-ui-level 【Temperature】
3. node-red-dashboard 【dashboard UI】
Thanx! now its imports well!
so how can I add sensors to lovelace?
And if I connect kc868-h8 with COL by rs232 what command I should send by TCP Socket to control relay?
KC868-H8 and KC868-COL both connect with Node-Red by different IP is ok. not need to use RS232 cable.
