07-06-2022, 12:56 AM
platform: ESP32
sda: 4
scl: 5
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.198
gateway: 192.168.1.1
subnet: 255.255.255.0
address: 0x25
- id: 'pcf8574_hub_in_3' # for input channel 17-24
address: 0x21
- id: 'pcf8574_hub_in_4' # for input channel 25-32
- id: 'pcf8574_hub_in_5' # for input channel 33-40
address: 0x26
- id: 'pcf8574_hub_in_6' # for input channel 41-48
address: 0x23
# Individual outputs
pcf8574: pcf8574_hub_in_2
pcf8574: pcf8574_hub_in_3
pcf8574: pcf8574_hub_in_4
pcf8574: pcf8574_hub_in_5
pcf8574: pcf8574_hub_in_6
[attachment=1093]
platform: ESP32
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
manual_ip:
address: 0x25
address: 0x21
address: 0x26
address: 0x23
[attachment=1093]
