this is a simple demo source code for KC868-A4 remote control relay by ESP RainMaker.
attachment=1131]
1. install arduino IDE with "Additional Boards Manager URLs":
https://raw.githubusercontent.com/espres...index.json
2. Arduino IDE "Board" chose: ESP32 DEV Module
3. Arduino IDE "Tools" -- "Partition Scheme" -- chose: "RainMaker"
4. Download code
5. Scan QRcode to add device.
Dear Admin
How can I use of 4 input to notification me if device On/Off in Rianmaker?
Can I help me?
Best regards,
Pouya
i have not tested, but rainmaker support notification function.
(07-19-2022, 05:39 AM)admin Wrote: [ -> ]this is a simple demo source code for KC868-A4 remote control relay by ESP RainMaker.
1. install arduino IDE with "Additional Boards Manager URLs": https://raw.githubusercontent.com/espres...index.json
4. Download code
Hi can you please send me all the info to setup a KC868-A16 with the rainmaker app, also i want to web browse to the device, thanks
thanks, can this all work through the LAN port, i would rather use that than the wifi? also do the inputs to trigger the outputs? is there a program or a way to web browse to it? or is it only done using code?
i have sent you the web server code: 1: input can trigger output 2: open web browser by wifi IP address. now the code work by wifi, in furture will let it work for ethernet.
here is video tour:
https://youtu.be/zmwWkROsKNY
(09-02-2022, 11:33 AM)davesmithr1 Wrote: [ -> ]thanks, can this all work through the LAN port, i would rather use that than the wifi? also do the inputs to trigger the outputs? is there a program or a way to web browse to it? or is it only done using code?
I think this code will help you:
https://www.kincony.com/forum/showthread.php?tid=2226
it's ethernet web server for KC868-A32, input trigger output relay. later we will update every KC868-A series board demo code with ethernet web server.
awsome!, can i apply the same solution to KC868-A8S board ??
thank you
