Technical Support
KC868-Server Raspberry Pi4 local server
> how to move CM4 eMMC home assistant data to USB driver
Full Version:
View the full version
with proper formatting.
admin
07-29-2022, 06:11 AM
if you are using CM4 8G eMMC version, installed home assistant and add-on. when you have not enough space of eMMC, you canĀ use "movedata disk" function, that can move your data to USB disk, save your eMMC space. it's easy.
fra6767ita
09-04-2023, 03:03 PM
Good morning,
I have low disk space, how to do? I can't find the commands.
Also because, as in another question, the USB ports are not working.
Thank you
admin
09-04-2023, 09:34 PM
have replied you this quesiton how to enable USB port in CM4 at another topic.
Technical Support
