08-04-2022, 09:47 PM
[attachment=1226]
platform: ESP32
# Example configuration entry
- id: bus_a
sda: 5
scl: 16
frequency: 400kHz
- id: bus_b
sda: 15
scl: 4
frequency: 400kHz
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.198
gateway: 192.168.1.1
subnet: 255.255.255.0
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
pcf8575: true
- id: 'pcf8574_hub_out_2' # for output channel 17-32
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_out_3' # for output channel 33-48
i2c_id: bus_a
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_out_4' # for output channel 49-64
i2c_id: bus_a
pcf8575: true
- id: 'pcf8574_hub_out_5' # for output channel 65-80
i2c_id: bus_a
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_out_6' # for output channel 81-96
i2c_id: bus_a
address: 0x27
pcf8575: true
- id: 'pcf8574_hub_out_7' # for output channel 97-112
i2c_id: bus_a
address: 0x20
pcf8575: true
- id: 'pcf8574_hub_out_8' # for output channel 113-128
i2c_id: bus_a
address: 0x23
pcf8575: true
- id: 'pcf8574_hub_in_1' # for a128-input channel 1-16
i2c_id: bus_b
pcf8575: true
- id: 'pcf8574_hub_in_2' # for a128-input channel 17-32
i2c_id: bus_b
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_in_3' # for a128-input channel 33-48
i2c_id: bus_b
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_in_4' # for a128-input channel 49-64
i2c_id: bus_b
pcf8575: true
- id: 'pcf8574_hub_in_5' # for a128-input channel 65-80
i2c_id: bus_b
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_in_6' # for a128-input channel 81-96
i2c_id: bus_b
address: 0x27
pcf8575: true
- id: 'pcf8574_hub_in_7' # for a128-input channel 97-112
i2c_id: bus_b
address: 0x20
pcf8575: true
- id: 'pcf8574_hub_in_8' # for a128-input channel 113-128
i2c_id: bus_b
address: 0x23
pcf8575: true
# Individual outputs
pcf8574: pcf8574_hub_out_1
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_out_2
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_out_3
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_out_4
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_out_5
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_out_6
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_out_7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_out_8
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
# Individual inputs
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_2
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_3
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_4
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_5
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_6
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_8
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
platform: ESP32
- id: bus_a
sda: 5
scl: 16
frequency: 400kHz
- id: bus_b
sda: 15
scl: 4
frequency: 400kHz
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
manual_ip:
i2c_id: bus_a
pcf8575: true
i2c_id: bus_a
address: 0x25
pcf8575: true
i2c_id: bus_a
address: 0x21
pcf8575: true
i2c_id: bus_a
pcf8575: true
i2c_id: bus_a
address: 0x26
pcf8575: true
i2c_id: bus_a
address: 0x27
pcf8575: true
i2c_id: bus_a
address: 0x20
pcf8575: true
i2c_id: bus_a
address: 0x23
pcf8575: true
i2c_id: bus_b
pcf8575: true
i2c_id: bus_b
address: 0x25
pcf8575: true
i2c_id: bus_b
address: 0x21
pcf8575: true
i2c_id: bus_b
pcf8575: true
i2c_id: bus_b
address: 0x26
pcf8575: true
i2c_id: bus_b
address: 0x27
pcf8575: true
i2c_id: bus_b
address: 0x20
pcf8575: true
i2c_id: bus_b
address: 0x23
pcf8575: true
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
# Individual inputs
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
