Full Version: [Arduino IDE demo source code for KC868-A128]--#04--LAN8720 code
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
IPAddress local_ip(192, 168, 123, 200);
IPAddress gateway(192, 168, 123, 1);
IPAddress dns(192, 168, 123, 1);
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
