Full Version: KC868-A8S_WS2812-RGB_LED
I am trying to use this example code
[Arduino IDE demo source code for KC868-A8S]--#08-KC868-A8S_WS2812-RGB_LED_code
but WS2812 is alway off.
PIN 12 is LOW.
I'm wrong, but I can not understand why.
I  test output, input (digital and analog), GSM, and RF433 using my code, everything works fine.
I can't get it to work (tried different code and library) is the RBG WS2812 led on the board only.
I tested my code on RBG WS2812 ring using a ESP32-Wrover-E and it works.
Can someone help me,  please?
Can someone tell me how I can download a demo firmware, when I turn on the board  the first time,  the led changed color.
I want to test the RBG WS2812 LED, so if I have broken it, I'll change with a new one.
Thank, best regards.
Marco
can you take a video of your problem, upload to google driver, leave the video link at here, i can check.
Hello!
I'm testing the RGBW LED on the KC868-A8S board, using the code:
light:
  - platform: neopixelbus
    type: RGBW
    variant: ws2812x
    pin: 12
    num_leds: 1
but when I choose a color, it doesn't turn on the chosen color, for example, if I choose the color red, the LED turns green.
Do I have to do some kind of calibration or use another code?
take a photo how you wire.
I'm using the LED from the KC868-A8S board itself:
"RGB LED WS2812.  If not have display, then at least a multi-color LED, which can also notify about various events and states of the system."
KC868-A8S
