Hello, I've just bought this device and after some preliminary tests I've noticed that IR range is terribly poor comparing to my another transmitter, which is a cheap Tuya based device.
Is it a matter of weak IR LEDs or reason is something else?
KC868-AI is not based on tuya solution.
can you open the box to test the IR range.
Maybe you can adjust the angle of the internal infrared emitter.
(09-08-2022, 11:32 AM)admin Wrote: [ -> ]KC868-AI is not based on tuya solution.
I've tried without the top case. It's a bit better but still below my expectations.
Tasmota's guides recommend usage of TSAL6400 leds. Are the ones used in KC868-AG on similar level in terms of effective IR range?
KC868-AG use IR333C-A 5MM.
