09-23-2022, 02:59 AM
i have removed RF433M receiver, RF433M sender and IR receiver. actually use want to use VCC,GND,RXD,TXD for Nextion display.
define RXD:GPIO23 TXD:GPIO21 by ESP32
here are some photos:
[attachment=1425]
[attachment=1426]
[attachment=1427]
This just a simplest demo, use Nextion display two buttons, press button-one will send 'a' by serial port, press button-two will send 'b' by serial port.
when KC868-A4 received 'a' will turn ON relay1, when received 'b' will turn OFF relay1.
firstly create two buttons UI by Nextion Editor PC software:
[attachment=1429]
[attachment=1430]
here is firmware BIN file, you can download to KC868-A4 ESP32 directly to use:
[attachment=1428]
here are source code:
[attachment=1425]
[attachment=1426]
[attachment=1427]
[attachment=1429]
[attachment=1430]
[attachment=1428]
String indata="";
String val="";
const int Relay1 = 2;
const int Relay2 = 15;
const int Relay3 = 5;
const int Relay4 = 4;
pinMode(Relay1,OUTPUT); //Relay1 IO2
pinMode(Relay2,OUTPUT); //Relay2 IO15
pinMode(Relay3,OUTPUT); //Relay3 IO2
pinMode(Relay4,OUTPUT); //Relay4 IO2
Serial1.begin(9600,SERIAL_8N1,23,21);
Serial.begin(9600);
while(Serial1.available()>0)
indata+=char(Serial1.read());
delay(2);
if(Serial1.available()<=0)
Serial.println(indata);
if(indata.length()>0)
val=indata;
if(val=="a")
digitalWrite(Relay1,HIGH);
Serial.println("Relay1-ON OK!");
else if(val=="b")
digitalWrite(Relay1,LOW);
Serial.println("Relay1-OFF OK!");
indata="";
