Full Version: KC868-A8 ethernet work with home assistant by ESPHome configure
[attachment=1574]
  platform: ESP32
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      number: 32
      number: 33
dallas:
  - pin: 14
  - platform: dallas
    address: 0x1c0000031edd2a28
(10-28-2022, 12:23 AM)admin Wrote: [ -> ]This is the error I get, I think it is happing when its compiling
INFO ESPHome 2023.12.9
INFO Reading configuration /config/esphome/alarm-io.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing kc868-a8 (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Wire @ 2.0.0
Compiling .pioenvs/kc868-a8/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/kc868-a8/src/esphome/components/api/api_frame_helper.cpp.o
xtensa-esp32-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/kc868-a8/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
*** [.pioenvs/kc868-a8/src/esphome/components/api/api_connection.cpp.o] Error 1
========================== [FAILED] Took 4.11 seconds ==========================
I don't know what is causing it?
  platform: ESP32
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  manual_ip:
      number: 32
      number: 33
dallas:
  - pin: 14
  - platform: dallas
you can test with DHCP mode.
To integrate with Home Assistant, is it better to use KCS firmware and MQTT or do everything with ESPhome?
Regards
KCS is more easier to use many functions. ESPHome need you config the yaml file.
update for ESPHome v2025.11.0
  friendly_name: kc868-a8
    type: esp-idf
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  manual_ip:
      number: 32
      number: 33
yaml file download:
[attachment=8670]
