We have designed KC868-HA RS485 button adapter, let your old switch or traditional switch become smart, work with KC868-H32B Pro smart relay controller, use any “Latch” or “Momentary” switch panel work with your smart home automation. This time, regular switch can be used in smart home system.
![[Image: detail_06.jpg]](https://www.kincony.com/images/KC868-HA/detail_06.jpg)
Hi
Is it working with KC868-32BS or KC868-32B?
Regards
Sten
now it's working with KC868-H32B Pro, in furture we will update KC868-H32BS' firmware to support it.
(11-23-2022, 10:53 AM)admin Wrote: [ -> ]now it's working with KC868-H32B Pro, in furture we will update KC868-H32BS' firmware to support it.
Hi
Thank you for quick response!
But update for KC868-H32B?
Do you have information when the new switch terminal board will be available?
Regards
Sten
Because H32B not have RS485 interface.
new switch terminal board will be available in next week, these days will take video tour about it.
(11-23-2022, 11:36 AM)admin Wrote: [ -> ]Because H32B not have RS485 interface.
Hi
Does the KC868-AH switch board support 1-click, 2-click , hold on actions? Like the KC868-AK switch terminal board
Regards
Sten
KC868-HA only support 1-click, because mainly use for old latch switch, that not easy for double click.
(11-26-2022, 11:11 AM)admin Wrote: [ -> ]KC868-HA only support 1-click, because mainly use for old latch switch, that not easy for double
Hi
Does the KC868-HA support updates? if yes, then do you plan this double klick and hold function update?
Regards
Sten
sure, KC868-HA support use firmware download tool as relay controller. if many user want double click function, we will update firmware to support it, hardware not need to change any.
(11-27-2022, 01:38 AM)admin Wrote: [ -> ]sure, KC868-HA support use firmware download tool as relay controller. if many user want double click function, we will update firmware to support it, hardware not need to change any.
Hello
Have you considered adding a double click and hold function to KC868-HA?
