Full Version: KC868-A8 Novice
Hi there,
I’m an Electrician and have recently built my own house. I’d like to be able to simply switch on and off a few circuits(eg. Lights, heating, electric gates, etc.) remotely using an IPhone app when I’m away from home. I recently bought a KC868-A8 controller but am a bit at a loss for what I should do next. I’m a total novice at ’Home Automation’ but I’d like to give it a go on my own house. Any help or advice would be greatly appreciated.
Thanks.
BOND71
do you will use "home assistant" software? because KC868-A8 mainly use for home assistant by ESPHome, or you can write arduino code, if you can't write code, just use esphome to config it. or if you don't want do anything code and setting, you can chose KC868-H32B Pro smart controller, it just directly to use without any coding.
